09-04-2006, 04:28 PM
Running lights
Has anyone had running/clearance lights installed on their H3? I am interested in getting a set put on mine. Just to let the other cars know I am bigger than they think at night.
2006 Slate Blue Metallic H3, FlowMaster exhaust, True Flow cold air intake system, Ground Force rear lowering kit, custom locking fuel door, chrome hood grill w/handle, US Speedo gauge kit (chrome and red numbers), Custom rear tire cover, chrome tail light guard, custom paint on skid plate, new pin stripping, USMC front license plate.  Semper Fi
09-04-2006, 04:44 PM
Re: Running lights
I had them installed when I got mine and love the look of them. I think they make the truck and actually make it look bigger.
09-04-2006, 10:09 PM
Re: Running lights
Can you post a pic?
2008 H2 Graystone Metallic
2006 H3 Black (sold)
previously known as Hmmm3
09-05-2006, 04:10 PM
Re: Running lights
Originally Posted by Hmmm3
Can you post a pic?
I think the lights and cross bows make the truck as well as make it look bigger.
Hear it is without the lights
A week later with them
Then with the cross bows as well.
09-08-2006, 08:42 PM
Re: Running lights
Wow, i thought it was just me that saw my H3 a little bigger since installing the crossbars:
 <- before
I'm looking to get roof running and PIAA lights next and already got those Husky liners for front, mid and cargo area - those liners rock!
09-12-2006, 01:05 PM
Re: Running lights
I just posted in another thread, but felt it was appropriate to repeat it here also. I had the marker lights added to my H3 and went through hell trying to get the wind noise and vibration stopped. Finally, after the GM fix kit did not work, they drilled another set of 6 holes and moved the lights back as far as they would go (AGAINST THE XM ANTENNA)! THAT FIXED IT!!! I have had it up to the rev limiter (99mph) on numerous occasions, in various directions and wind conditions, in clean air and behind 18 wheelers, and not a sound or irregularity. So I guess the answer is to make sure the lights are back against the XM antenna and you should be good to go! If they are not back that far, the wind coming off the windshield is subject to catching the leading edge of the light bar and causing the noise and vibration. The difference I'm referring to is only 3/8 inch, but that little bit seems to allow the wind to pass over the light bar without catching the leading edge of it. Have a great H3 day!
09-05-2006, 12:19 AM
Re: Running lights
Where did you get them? What did you use? Who installed them? If you did it, how did you wire them? Got photo?
09-05-2006, 08:54 AM
Re: Running lights
It's a dealer installable option, or you can buy the OEM kit and install it yourself. I had mine installed by the dealer just before I took delivery. I think the lights really give the vehicle that "Hummer look" as well as increasing visibility/safety.
09-05-2006, 04:13 PM
Re: Running lights
I got them when I bought the truck. I took delivery that night and had it scheduled for a week later to get the marker lights and DVD headrests installed. I would have the dealer do it since you have to drill into the truck as well as the fact that there have been wind noise issues. If you have problems and install it yourself then you it's all on you. If the dealer does it you just take it to them if there is an issue.
09-05-2006, 07:50 PM
Re: Running lights
Very nice!!
09-06-2006, 11:37 AM
Re: Running lights
Have you had any "wind" noise problems with your set up? It does look more finished on your H3. We both have the same color, want to trade?
09-06-2006, 08:34 PM
Re: Running lights
I had wind noise issues that took them a little while to fix but they got it right on the third try. It has now been 4 months and they have not been a problem. I do get the vibration noise every once in a while but only for a second and it goes away. Must just be a cross wind or something that just happens to catch it right.
Great color choice. Sure, I'll trade, but you have to buy all new stuff for me to put on it after we trade
09-06-2006, 12:40 PM
Re: Running lights
No wind noise problems on mine...but I've only had it up to maybe 70 mph. I'll do a hundred and stick my head out the window and let you know.
09-06-2006, 01:23 PM
Re: Running lights
You'll never get to 100, H3 shuts down around 94.
Hybrid Mode
