09-06-2006, 09:41 PM
can the sensor for the air ride be tricked?
I have added the 2" torsion key lift to my H2 and it sits higher in the front now and kinda sags in the rear. Is there anything I can do to trick the sensor for the air suspension to ride higher?
2003 Hummer H2 LUX...sold
2006 Hummer H2 SUT LUX...sold
2018 Polaris GEM e4
2022 Can-Am Maverick X3 XRS Turbo RR
2024 Rivian R1S Adventure
2024 GMC Sierra AT4X HD
2024 GMC Hummer EV 2X SUV
09-07-2006, 08:26 PM
Re: can the sensor for the air ride be tricked?
Originally Posted by PhilD
Adjust the air ride sensors. They are adjustable up to '05.
where do I adjust the sensors...what tool do I need to do this? instructions needed please.
2018 Polaris GEM e4
09-09-2006, 03:45 AM
Thanks, I will take a look at it when I get some time.
2018 Polaris GEM e4
09-09-2006, 06:08 AM
Can someone post a pic of the sensor location? I've looked under there a couple of times, and can't really figure out where it's at...
'03 H2
09-09-2006, 05:08 PM
You can't miss it, it is the only thing connected to the frame in the rear wheel well.
I don't see where they can be adjusted, guess I will take a closer look after some more coffee. I know my friends H2 seems to sit almost an inch higher and she doesn't have air suspension.
09-09-2006, 08:10 PM
Ahhh..was wondering what the h*** that was...
'03 H2
09-09-2006, 06:13 PM
As far as I know, and I don't have air to check this, the two bolts holding the arm to the frame mount allow a little adjustment. Sometime mid cycle '05 this was changed and there was no adjustment.
FWIW On the Fabtech lift kit, which is not suitable for air ride H2's with the non adjustable sensor, it uses a bracket with plenty of room for adjustment.
I may well be wrong, but from what I've been told there is adjustment in the air ride on the earlier H2's, although the manual says there is no adjustment. Maybe it is at the other end of the sensor, the part attached to the uppoer control arm.
I will check it out later and see if theres any play to slid the sensor with the bolts loosened up. It always adjusts apon startup, so I think the hieght difference bewteen our rigs was.
A: had been sitting for hours.
B: my tires are about 5k away from being toast and hers are like brand new.
Hybrid Mode
