09-13-2006, 03:03 PM
Air suspension issues (or "#%$@!" again!)
I've got a 2003 H2, adventure pkg with air suspension.
Here's the problem that defies logic, about 75% of the time after the truck is parked for a few minutes, the air suspension will be totally lowered. When I start it, it returns to ride height.
The first reaction is there is a leak, but that doesn't explain why it isn't consistantly flat. It also seems the suspension is constantly changing, I hear it cycling at stop lights on flat ground sometimes.
I've gotten no warning lights and I always wait a minute or two for it to inflate before driving but the problem seems to be worsening and lately has affected ride height on the highway.
After searching this site I didn't see any similar problems and I'd rather fix it myself. My first guesses are either of the position sensors or a relief valve.
Has anyone had a similar problem? My concern is the dealer might be inclined to replace more than necessary.
09-13-2006, 06:07 PM
Re: Air suspension issues (or "#%$@!" again!)
This has been talked about a lot here! The 03's had the most issues with the air susp. IMO. I lost two air bags and had a few dealer trips due to the air susp. on that truck. Because of this happening, I was also stranded on a trail.. AFter that, I opt. for no more air susp. Solid steel springs make me feel better about the susp. and saftey on trails. Others have zero issues.
So, yes your compressor will turm on and off while driving and sitting at stoplights. That part is normal.
When you come out to your truck in the morning and it's sitting low, that's not good. Do you have anything screwed into your fitting in the back of the truck (where you screw your hose into) If so, unplug it, that's your issue.
You can check your ride height arms in your rear wheel wells to see if they are damaged.
Otherwise off to the dealer you go.
If you're really sick of this issue, you can swap out the air bags for springs. It may be a cheaper route if you are out of warranty.
09-13-2006, 06:46 PM
After having experienced just about every kind of air suspension(AS) problem possible I can tell you that the two main areas of concern are the AS sensors and the air bags. Back in '03 when I had most of these problems finding & fixing them was a major endeavor for the techs as the system was still new to them. Now they know exactly what to look for.
09-13-2006, 06:51 PM
No Air, No Problems!
09-13-2006, 06:52 PM
I agree. Try GasEx for this.
09-13-2006, 07:35 PM
I have air ride also on an '03 and it is always clicking on and off at a stop light or drive thru and that is normal. As we all know when the truck is not running there is no pump, so my uneducated guess it has to be a leak somewhere in the pillows or line, because when the truck is running the pump keeps them inflated so it has to be a SMALL leak, leaking when the truck is off. Check the most obvious first. Thank you and good night sir!
09-13-2006, 08:22 PM
That would be me. 2003 bought in Feb '03 and have never had an air problem.
However, I have noticed that my air levels out and different heights. Appears that it's varies by about 1" or so. I know this because sometimes my rig with new 37s hits the top of my garage door, sometimes it doesn't.
09-13-2006, 08:35 PM
I had the same problem. It turned out to be a leaking bag. What was weird is that it was intermitant. Some days it would stay up and others it would sag a little and sometimes it would go all the way down. It took two dealers to figure it out.....
1994 Chev Suburban Blown
09-14-2006, 06:07 AM
If this is an early model H-2 with A single stage compressor there is a programming update to address your concern, talk to your dealer tech and he should know about it. Likely the service consultant or service manager will not have the info.
09-19-2006, 02:39 PM
I thought I'd post a follow-up here to complete the archive. I took it by the dealer and they said it's the airbags so I feel like I've dodged a bullet of sorts since the compressor is okay.
The bags were $158.00 each (thinking I saw a post here mentioning $90 each?) plus labor and will be installed this Friday.
I'd planned to look at the system this weekend, but a very enjoyable soccer tournament kept me busy. Yesterday evening I climbed under to have a look and both air bags are dry rotted and cracked badly, it's a wonder they hold air at all.
I wonder if I got a bad original set, or if some preventative protectant should be applied when the new ones are installed? It's lame that these would go out due to deteriotation at 70K miles.
09-19-2006, 02:51 PM
x2
mine is a July '02 version and I got the update because I was having an abnormal about of cycling.
Hybrid Mode
