Old 09-20-2006, 05:39 PM
H3 Alaska's Avatar
H3 Alaska H3 Alaska is offline
H3 Alaska is off the scale
Default Any one else having this check engine light?
All 3 (mine/wife/brother in law) of ours have had a check engine light in the last 2 weeks.
Wife: P300 engine misfire
Mine: P302 engine misfire
Brother in law: who knows (whole other story)
Mine only happens after the "low fuel" indicator comes on. ??????????
Once I fill up the tank, it goes off.
The wifes goes off and on at random.
All have less than 10K, but more than 8K miles.
Wife's is going in for cylinder head replacement today.
f5stop? Any suggestions?
Regards,
Dan
2006 White H3, Adventure package, stock for now, 2006 Black H3 Adventure package with a few extras.
Old 09-20-2006, 08:46 PM
Default Re: Any one else having this check engine light?
Mine has gone on as I have experimented with air intake mods.
Old 09-20-2006, 09:51 PM
Regards,
Dan
If there is a rough or rougher than usual idle with those codes, a new cylinder head is coming your way. However, if no idle and the light only comes on when the tank is real low, I might say it could be a fuel pump. Lack of fuel is causing a misfire, setting the code. Not a usual occurrence, but it could happen.
When the low fuel is on, what is your fill up in gallons? It could be your low fuel light is coming on too late, and you are about out of fuel and the pump is starving a bit.
Old 09-21-2006, 02:20 AM
H3 Alaska's Avatar
Last night when it happened I only put in $15 because I was late for dinner at my sons, and of course everyone was waiting on me.
I will look back at some recent fuel receipts and post back.
The wife's did have a rough idle, but mine does not.
Old 09-22-2006, 12:32 AM
Hummergyrl Hummergyrl is offline
Hummergyrl is on a distinguished road
There is a known issue/bulletin out on this issue for P0300 thru P0305 Emissions misfire DTC. You will get a Check Engine Light and may or may not experience rough idling. *Some* VINS under 287591 have these parts that were machined wrong or something and need to be replaced. The new parts contain harder intake valve seats to prevent intake valve wear and leakage.
This happened to me last week. My H3 (7,500 miles) had been idling a little rough for a couple weeks and then got the Check Engine Light. Onstar diagnosed the DTC and said to go directly to the dealer. The dealer replaced some intake valves and the cylinder head. Runs great so far. Sad to see my brand new H3 with the motor torn apart though.
Nothing to do with gas folks, get it fixed asap!
Old 09-22-2006, 02:44 AM
smh3 smh3 is offline
smh3 is off the scale
Smile Re: Any one else having this check engine light?
Took mine to about 12,500'. All kinds of things came on. Long story short it was a Mass airflow sensor.
Old 09-29-2006, 06:26 PM
Talking Re: Any one else having this check engine light?
H3 Alaska did your wife's get the cylinder head replacement? Did it resolve the issue?
Mine is still running good...
Old 10-11-2006, 10:46 PM
macwag's Avatar
macwag macwag is offline
macwag is an unknown quantity at this point
Yes. My engine check light went on yesterday at 10,300 miles. My brother is a GM mechanic and he said there is a new cylinder head heading my way.
2006 H3, Black, Luxury, Off Road, Automatic Transmission, Sunroof, Trailor Hitch Package, XM, Mud Flaps, Black Assist Steps
Old 10-16-2006, 07:43 PM
H3 Alaska's Avatar
Just took it back in this morning because it was running rougher than before the new head. Service advisor said it's a "cam shaft sensor".
