Old 09-28-2006, 11:49 PM
Default Might need new H2 sooner
Might have to get something sooner than expected.
After some hard wheeling a month or so ago, I was heading down the Interstate towing a Jeep behind me on a trailer. Not only was the wheeling pretty hard, it was extremely dusty out. So as we are tooling along, I get a check engine light. We stop and check it and it's some Mass Air Flow sensor code.
Reset and go on and the code is thrown again a few more times over the past month ( I don't put many miles on my truck - 08/02 with less than 35K )
Decided today to take a look at it, and apparently back when my A/C went out on the way to K-rocks a few months ago, they took the intake tube off. When they reinstalled it, they folded over the rubber gasket where the MAF mates to the air box and there was a bad wrinkle in the rubber gasket. The MAF was throwing the code because it was getting surges of different air pressure as the truck torqued, I assume, and pulled on the gasket opening up and letting air through.
UN_FUCKING_FILTERED AIR
I better not have to stop in Waco again anytime soon or they are going to have another mofo Waco on their hands.
Old 09-29-2006, 12:00 AM
Default Re: Might need new H2 sooner
That blows! Sorry to hear that.
Old 09-29-2006, 12:50 AM
mikejr's Avatar
mikejr mikejr is offline
sons a bitches.....thats all i can say....sons a bitches.....
2009 H2 Silver Ice LE
Old 09-29-2006, 04:04 AM
NSANE NSANE is offline
NSANE is off the scale
That does suck, in a bad way!
2006 H2, Black with bling!!
Old 09-29-2006, 05:59 AM
dochummer's Avatar
OUCH! Time for a Duramax upgrade!
'03 H2
Old 09-29-2006, 03:15 PM
Originally Posted by PhilD
Mine was like that after the dealer did the 15k service. 30k miles later no problems.
It is really to do, and extra care needs to be taken when putting the intake tube back on.
That would explain the blue smoke coming out of you........... ummmmm
nevermind,
really? no problems.
Old 09-29-2006, 04:40 PM
H2 GTS's Avatar
H2 GTS H2 GTS is offline
H2 GTS is on a distinguished road
I don't understand, Un-Filtered Air is organic and nutrient rich just as God had intended. So called Filtered-Air may have been altered in the process and lacks the nutrients your V8 needs. Who knows what harsh petroleum derived chemicals left-over from the filtermaking process, make their way into every breath your engine takes. Go natural. Every filter you buy contributes to the Global Warming of the Holes in the Ground-level Ozone Layer.
Dwight: Second Life is not a game. It is a multi-user, virtual environment. It doesn't have points or scores. It doesn't have winners or losers.
Jim: Oh, it has losers.
Old 09-29-2006, 04:49 PM
I was in your neck of the woods when it started throwing MAF codes.
Can you post your address, so I can have a place to go steal... umm.. er.. borrow parts in case I break some in a couple of weeks. Coming back over to Bham to do more vehicular damage.
Old 09-29-2006, 04:59 PM
It's shame you can't rely on repair shops or dealers (or even Jiffy Lube for that matter).
I can help you out if you need anything welded.
Old 09-29-2006, 09:58 PM
I can help you out if you need piano or sewing lessons..
FIXED!
Old 09-30-2006, 02:00 PM
It get's worse
Drove to the farm yesterday and was turning around to back in to a spot. It's a little drop and I was wheels cut full to driver. Had a clunk.
Been having a clunk and it felt like the skid plate as before.
This time I felt it strong in the steering. Got to going back and forth between Drive and Reverse and it was clunking bad. Crawled under while someone else shifted back and forth and the DS output shaft is where it is coming from. Was hoping it was CV related but I swear most of the movement seem to occur near the Diff
Really "acts" like the inboard CV is going out but it gives you the illusion that the output shaft on the diff "wobbles" around when you go from D to R and back and forth. But, there is no leaking of fluid there.
Will investigate it further when I get back to the house.
Old 09-29-2006, 05:06 PM
H2 GTS's Avatar
Yeah that sucks though. You think it is worrisome to have people work on your truck these days, try having them work on your airplane. we have had engines ingest airfilters that were not secured properly or installed inside out. A 550 cubic inch 6 cylinder will suck the filter right down into the cylinder in a flash
Old 09-29-2006, 05:12 PM
about that address
Old 09-29-2006, 07:55 PM
HummBob's Avatar
HummBob HummBob is offline
Here ya go PARAGON. Your NEW Rig
http://cgi.ebay.com/ebaymotors/Hummer-H2-2006-HUMMER-H2-DURAMAX-DIESEL-500HP-23-MPG_W0QQcmdZViewItemQQcategoryZ43913QQihZ019QQitem Z290034694523QQrdZ1
BLACK \'04 H2 LUX
BLACK \'07 ESCALADE
