Old 07-17-2003, 03:27 PM
ICEMAN ICEMAN is offline
ICEMAN is off the scale
I am planning on removing the roof rack on the H2.
I don't really need it and it make the vehicle too tall.
I've seen some H2's without the rack and I like the clean lines better.
How hard is it to make the roofline smooth?
I'm currently awaiting delivery on my H2.
Larry
Larry
Old 07-17-2003, 09:30 PM
Zyx5432 Zyx5432 is offline
Zyx5432 is off the scale
FYI, the stops in the back have one clip in the far rear (where this is a tab you push towards the front of the vehicle to release) and one that requires a screw driver to release. The latter is on the outside, about 1/2 to 2/3 of the way towards the front.
Then, repeat on the other side and presto, your rails will slide right back and pop out.
Old 07-17-2003, 04:01 PM
SJ SJ is offline
SJ is off the scale
ICEMAN:
The sliding roof racks can be removed from the H2 with ease. I took mine off to see how it would look and now have them back on again.
There is a set of stops at the rear portion of each track. You'll need to remove a clip that holds each stop and then slide the racks all the way to the back to work them out of the tracks.
________________________
\'03 H2 [Sold]
\'03 Chevrolet Silverado Z71, 6\" Rancho Lift, Rear Factory Locker, 35\" ProComp MTs
http://www.smiliegenerator.de/smiley...miley-9839.png
