10-15-2006, 04:40 PM
REAR SUSPENSION NOISE
Anyone of you noticed a completely insane creaking noise in the rear spring leafs??
I had it for almost 1 month, then change the bushings by a poliurethane ones but the noise continues...
10-15-2006, 09:26 PM
Re: REAR SUSPENSION NOISE
Which bushings did you change out? Could it be the rear sway bar bushings?
10-16-2006, 07:39 AM
Mine creak really bad. But then my DS rear suspension is beat to hell.
10-16-2006, 05:02 PM
Might want to crawl under and check for broke leaf right at the bushing site. My right rear broke there last summer. Right were it curls around on bushing. It was broke for awhile(alot of rust on break) and it finally flew off was the only way I knew. Dealer overnighted one in and I had it back the next day.
11-19-2006, 03:56 PM
It has oem bushings. The creacking noise comes from inside the bushings but more from the front ones. I removed the spring leafs but not noticed anything wrong
11-19-2006, 07:30 PM
ive got a creaking noise too, sounds like its from the back, but havent been able to confirm that yet. let us know if you come up with a fix.
11-20-2006, 05:03 PM
Have only 7500 miles on my H3 and the creaking noise is insane and unbearable.
I think is for a deformation of the bushing sites on the spring leafs, cause when I move the truck up and down, they moves laterally. Note the bushing sites are open not completely welded.
01-12-2008, 12:28 AM
X Racer, I have 4800 miles and and an insane squeak/creak as well. Were your successful in quieting the springs?
Hybrid Mode
