Old 10-17-2006, 11:43 PM
aetherH3 aetherH3 is offline
aetherH3 is off the scale
Default Why didn't Hummer go with 2WD w/selectable 4WD?
I'm curious as to why they decided to use an ALL-TIME 4 wheel drive system when they could have used a 2 wheel drive system for normal driving? It would increase gas mileage which would make the H3 more appealing to customers and also bring down the quotas (whatever its called) on the MPG ratings for GMs line up. After all, the H3 was built as a more efficient Hummer. It would also increase engine performance because of less drag. I imagine our H3s would be pretty peppy only having to turn two wheels instead of four. Not that I'm complaining, just wondering.
Old 10-18-2006, 12:01 AM
ROADNOTCA's Avatar
ROADNOTCA ROADNOTCA is offline
ROADNOTCA is on a distinguished road
Default Re: Why didn't Hummer go with 2WD w/selectable 4WD?
The aftermarket will probably have a conversion in a couple years, but yeah, X2.
Old 10-18-2006, 12:04 AM
I'm not sure how I feel. I like having a vehicle in 4WD all the time. But yet 2WD would help the MPG. As long as there was no 2WD only, I couldn't imagine it would be too much a problem.
Old 10-18-2006, 12:24 AM
Because it is a Hummer and Hummers have full-time four-wheel drive. In addition, the extra fuel mileage is not as great as people believe. Even with a part time 4x4, you still have the gears turning creating a drag and producing friction, thus reducing fuel mileage. I was told it would equate to a max of 1 mpg (per some testing).
Drive one without the front prop shaft...you won't notice much of a difference.
Next, someone is going to want a two-wheel drive only H4.
Old 10-18-2006, 12:37 AM
Desert Dan's Avatar
Full Time 4x4 should have been an option.
Maybe they did it for safety and to prevent us from spinng the rear tires and getting sideway in the dirt.
Desert Dan
Jeep TJ Rubicon 2003
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
Old 10-18-2006, 12:48 AM
ROADNOTCA's Avatar
You cannot drive without the front D-shaft because of the torque converter in the T-case. Ask me how I.....
Old 10-18-2006, 01:12 AM
DURAMAX TIM is off the scale
lock it in 4 hi then it'll go.
98 ZR-2 Blazer
Ex H2&3 owner
Old 10-18-2006, 01:48 AM
ROADNOTCA's Avatar
Ho, look out!
Old 10-18-2006, 10:51 AM
Duh! Guess I missed the torque converter in the t/case. Could you help me out and tell me which number the torque converter might be?
And might I ask how you know?
Old 10-18-2006, 11:34 AM
ROADNOTCA's Avatar
I'm not an expert, so do we get the 40/60 split from a planetary? #203 for eg.?
Old 10-18-2006, 04:56 PM
More complicated than that, but primarily the differential planetary splits the torque to 40/60; item 231. There is no torque converter in the t/case.
Old 10-18-2006, 01:41 AM
Cool responses! I'm DEFINITELY NOT suggesting that they should have made an H3 with 2WD ONLY!!!!! I was just wondering why they made it an ALL TIME 4WD.
Old 10-18-2006, 02:51 AM
Wisha Haddan H3's Avatar
I see the full-time 4wd as a huge advantage. Don't know how many times in my part time 4runner or blazer when rear wheel drive didn't cut it. Any ice or slush and I'd fishtail, even with BFG ATs. And you can forget going uphill from a stop if it's icy.
But I can even tell the difference cruising in dry conditions. Fulltime 4wd delivers better control and cornering up in the canyons. Definitely wouldn't give it up for 1 mpg.
