Old 10-27-2006, 12:01 AM
mudderducker's Avatar
mudderducker mudderducker is offline
mudderducker is off the scale
Default 37" tires?
anybody work at a tire shop (or know somebody at one) that has tried to put them on a stock 3? Of course, it would have to be torsion cranked. I have a theory that a skinny 37" may fit. say 37x10.5-12.5. I come from the Land Rover world, so tall and skinny tires look and function great. The theory being that there is ample room for 2 more inches up and down, left and right would be tight; but skinny may work. the advantages are clear: an additional 2" of ground clearance (over 33" stock tires). any input?
_____________________
Land Rover Convert - H3 ADV
http://www.deltawaterfowl.org/
http://www.ducks.org/
http://www.joincca.org/
Old 10-27-2006, 12:08 AM
Desert Dan's Avatar
Default Re: 37" tires?
I doubt the front diff and the I-5 would hold up well with 37" tires
What are you thinking? Michelin XCLs?
Desert Dan
Jeep TJ Rubicon 2003
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
Old 10-27-2006, 12:28 AM
well, I thought there would be many choices, but super swamper has this one:
http://www.4wheelparts.com/4wp/products/productLine.asp?width=12.5&height=37&rim=16&search =true&cat=TIR&catName=TIRES&man=INTE&linecode=INTE &prodline=1024
Old 10-27-2006, 12:48 AM
I'm sure you could get them to fit. Just make sure you drive in a straight line on perfectly flat ground.
Old 10-27-2006, 12:58 AM
Exclamation Re: 37" tires?
And make sure that you can tolerate truly slow acceleration as your H3 will become especially gutless.
S.
Old 10-27-2006, 03:34 AM
top speed in the LR was 80 mph, so the h3 is a camaro in comparison mind you, that was with a v8. damn those motors suck; but duct tape, bubble gum, and tampons is all you need to fix one.
but, I'm really just thinking outloud, outside the box.
