Old 11-16-2006, 03:53 AM
Gunzz's Avatar
Gunzz Gunzz is offline
Gunzz is off the scale
Default Dash removal
Hello all. I recently had a stereo installed and now the dash panel around the radio and air controls, on star and switches seems to be popped out slightly. I took it back and they made it better but not perfect. I am anal when it comes to these things.
So I figure to get it done right I will have to do it myself, but I do not want to break the dash trim. So can anyone here tell me the proper way to remove this trim piece and where the clips might be located that hold it in? I know there are the 2 bolts near the air ducts but is that I all need to remove to slide the panel up and out or do I have to remove the center console first?
I need to do this right away before I have to go into therapy for an improperly fitted dash panel.
Old 11-16-2006, 03:58 AM
HummBob's Avatar
HummBob HummBob is offline
Default Re: Dash removal
The whole center console needs to be removed. Do a SEARCH...Someone had this posted a little while ago!!
BLACK \'04 H2 LUX
BLACK \'07 ESCALADE
Old 11-16-2006, 04:02 AM
HummBob's Avatar
Nevermind. I'm BORED at work, so I found you the link:
http://www.elcovaforums.com/forums/s...ht=remove+dash
BLACK \'04 H2 LUX
BLACK \'07 ESCALADE
Old 11-16-2006, 08:42 PM
Gunzz's Avatar
Thank you for the link. Gives me all the info I need.
Old 11-16-2006, 08:48 PM
HummBob's Avatar
Glad I could help!!
BLACK \'04 H2 LUX
BLACK \'07 ESCALADE
