Old 11-28-2006, 01:48 PM
TXSUT's Avatar
TXSUT TXSUT is offline
Default Question - rear mounting of larger tire/wheel
I've been running with an OEM spare, but when I got my new Toyo M/Ts (37x13.5x18) last week, I bought 5 and a new 18x10 wheel to mount the spare on. Tha backspacing on the wheel is 4.5". Am I going to have any issues with mounting this larger tire/wheel combo on the the OEM tire carrier?
Thanks,
Pete
Old 11-28-2006, 04:25 PM
Default Re: Question - rear mounting of larger tire/wheel
Thanks,
Pete
Man up and stick that SOB up there and see if it works.
Then go boil me up some crawdads.
I think others have run a similar setup. If not, you could just get the some lug studs replaced with some longer ones.
Old 11-28-2006, 04:38 PM
lasvegash2's Avatar
lasvegash2 lasvegash2 is offline
lasvegash2 is on a distinguished road
yes it will work...mine is 18 x 9.5 with 4.25 backspace with a 38.5 x 14.5 tire. i had the same concern, but no problem
scott j.
2008 h2 sut
2008 escalade
1969 charger
Old 11-28-2006, 07:11 PM
TXSUT's Avatar
Thanks LV!
Old 11-28-2006, 07:13 PM
TXSUT's Avatar
I haven't gotten the tire mounted on the wheel yet, or else I would have tried it myself.
And (good) crawfish are out of season...you know that!
Old 11-30-2006, 06:50 AM
rocketw19's Avatar
yep fits no problem. one thing how is your center cap? mine had a small diameter and i had to cut off the part that sticks out and holds the license plate light.
Old 11-30-2006, 09:27 PM
TXSUT's Avatar
It's large diameter, so I should be okay. Thanks!
Old 11-30-2006, 10:48 PM
murf's Avatar
murf murf is offline
murf is on a distinguished road
That will fit, my 38x15.5x18 fit on the outside carrier before I removed it, and actually it opened easier with the bigger tire on it.
Thanks,
Pete
Old 11-30-2006, 11:02 PM
TXSUT's Avatar
Thanks Murf!
Old 12-01-2006, 01:03 AM
tomp's Avatar
tomp tomp is offline
Tire/wheel may wobble a bit down the road as it will no longer fit up against the tire carrier the same way as it did before.
Old 12-04-2006, 07:26 PM
TXSUT's Avatar
Got it mounted. I had to shim the wheel away from the mount to account for the fact that the thickness of the Weld wheel's hub is less than that of the OEM wheel. I also had to hack the crap out of my license plate holder to make it line up correctly, so I'm thinking about relocating it to the bumper.
Thanks again for everyone's input.
Pete
Old 12-04-2006, 09:17 PM
Pete
Pull your wheel back off. Take a grinder to that hub that sticks out and throw that license plate bracket in the garbage. You have a very nice wheel and it deserves full view back there. Once you cut that hub off, black touch up paint, put your new center cap on. And your done with that. The plate you can mount on teh PS SD next to the tow hook. I posted some pics on an earlier post. Auto zone will have a light you can screw to the bottom side of your tire carrier.
Old 12-08-2006, 12:37 AM
JDLarue's Avatar
JDLarue JDLarue is offline
JDLarue is on a distinguished road
When I tried to put a 37x13.5x17 Toyo M/T on a stock rim on my rear tire carrier it went on but the two studs at the bottom had just a few threads showing and the top two had all threads showing. So it would have worked but the tire was sitting at a goofy angle with the top closer to the body than the bottom. The problem was the bottom of the tire was hitting the arm of the carrier. For what it's worth.
