Old 12-19-2006, 04:48 PM
ratesguy ratesguy is offline
ratesguy is off the scale
Default oil pressure
Oil pressure gauge looks to be pegged at 80(normal is around 40). Had work done last week(resealed valve covers, engine knock sensor replaced), but just noticed the gauge. Anyone have any experience with high oil pressure or what could cause a high reading? My first thought is "shudder" a low engine block lock.
Old 12-19-2006, 04:51 PM
GLBLWARMR's Avatar
Default Re: oil pressure
Is the guage stuck?? Does it drop when you shut it off?? That is my first thought maybe the guage just chit the bed. Other than that I do not have anything else.
2006 H2 w/6 inch lift.
2001 F-350 w/10 inch lift
2013 Victory Cross Country
2006 Suzuki Hayabusa
Old 12-19-2006, 05:55 PM
Yes, it drops to 0 when the vehicle is turned off.
Old 09-04-2009, 12:36 AM
SoWhat SoWhat is offline
SoWhat is on a distinguished road
Unhappy Re: oil pressure
Same problem with my 2003 h2, always at 80 when running, back to zero when off. Just had oil and filter changed, (Royal purple 5w-30, mobil 1 filter), Should I change out the gauge, or some other part unknow? Thanks
Old 09-04-2009, 12:12 PM
funnone's Avatar
funnone funnone is offline
funnone is on a distinguished road
I'm guessing that the Sensor is unplugged or bad!
I don't know were it's located on the H2, But On my vette It's under the Manifold towards the the Back! They go Bad all the time and the gauge will read 80.
Old 09-04-2009, 12:47 PM
HummerMann's Avatar
It sounds like the oil pressure sender gone bad. It's in the back of the block behind the intake manifold. I steam cleaned my wire off and it went to 0 years ago.
Hummer, like nothing else
Old 09-05-2009, 06:19 AM
Yeah switch to a K&N filter and Mobile 1 oil..............
