01-04-2007, 05:16 AM
H3 Accessory wire by the radio
Hello,
I am installing a sirius sportster4 and I have hardwired a cigarette power adapter from radioshack using the orange and black wires on the back of the radio harness. This obviously is always on due to the orange being a constant hot, but i would like the sirius unit to turn off with the key.
Does anyone know what wire is the accessory wire controlled by the key, which I can connect to instead of using the Organge one?
Thanks,
Josh
Car is 2006 H3 with the most basic stock radio, no xm or 6 disc, or nav, or even mp3 player.
01-04-2007, 05:56 AM
Re: H3 Accessory wire by the radio
I think the red is a ignition on wire. There is also and accessory wire but i dont know which one it is. Im sure someone with better info will post soon.
01-04-2007, 11:56 AM
Brown wire into the gray 12-pin connector at terminal K, is ignition 3 voltage and controlled by the BCM via the HVAC relay. There is no ignition On voltage to the radio.
01-04-2007, 03:49 PM
Great thanks for the help!!!
Can someone provide the location of Terminal K? Is this one of the 2 connectors that go into a metal box after I pull the radio/climate control cover off?
Thanks and Best Regards,
Josh
01-04-2007, 04:14 PM
If you use ignition wire it wont be powerered on accy.(key back)
There is a yellow wire on the rear wiper switch that runs key fwd((ign) and key back(accy) I would run it to power a relay than use the positive wire from the accy plug or the red wire on the trailering wires under the steering wheel on the right to power your accy.There is also a ground located there.
01-04-2007, 06:27 PM
Josh
the metal box is the onstar box, i have no idea where terminal k is, but there is a grey connectors on the "radio/climate controm/console" cover, that might be the one.
01-04-2007, 07:20 PM
Sometimes I feel like such a idiot, and now is one of those times. I have no clue about anything you guys are saying.
Thank god for people who do this for a living and liking my business they get.
F5 and 442, you guys deserve props for always helping out.
01-04-2007, 07:27 PM
I forgot to say, at the HVAC control head.....When you pull off the trim cover around the radio and HVAC, it will be behind the cover, since the HVAC controls come off with the cover.
fourfourto: You are correct, the yellow wire will be hot in accy and run. However, in regard to a ground, since this is a new electronic receiver type device, the person should make a new ground just to be sure it is clean enough for the new module that was not designed in by the manufacturer.
Hybrid Mode
