Old 01-06-2007, 07:05 AM
jdrew's Avatar
jdrew jdrew is offline
jdrew is on a distinguished road
Default Fuel tank question
I have noticed that if I fill my tank with it at 1/2, that it will only take about 6 or 7 gal to fill.. isn't it a 23 gallon tank? Shouldn't that number be a little higher, like 10-12 gal to fill?
I have also noticed that in both of my h3's that if you fill it to the top, you will only get about 30-40 miles before the gauge shows it back to the F on the gauge.. In the wifes jeep and my other cars I have known, if you top them off, you can get 50-75 miles before the needle gets past the F mark...
Anyone else notice this? Or am I in a very unique situation..
Secondly, is there a low fuel warning of some sort? I never let it get that low to find out.. But I may just to see how much it will take..
Thanks for the replies!
Evansville, IN
'05 H2 SUT Slate Blue LUX w/Nav, NightDriver
H.O.P.E. Member
Old 01-06-2007, 07:31 AM
marin8703's Avatar
Default Re: Fuel tank question
I also get about 30 miles for it to come back down to the F if it was topped off. There is a low fuel warning. When you reach the low fuel level you hear a chime (like the open door sound) and in the DIC your see the message "LOW FUEL". if you press the stem it will go away but after a while it will come back again. There is no light on the Instrument cluster that shows a low fuel warning like in most vehicles, its just on the DIC (not that another light is needed). After the initial warning you have about 3 gallons left, which is in most situations plenty.
Old 01-06-2007, 07:32 AM
3Hummer's Avatar
3Hummer 3Hummer is offline
i only filled my tank once and i only filled 19 gallons and it was empty so i thought the tank only holds 20, if its more then i got much worse gas mileage than i thought! Not good! And also when i fill my car it goes past full the needle shows like full plus 20 percent
2017 VW Jetta S
2012 Cessna 182T Skylane
/''T''|[___|___]
[---T--L -OlllllllO-]
()_)"""()_)/"**"\)_)
Old 01-07-2007, 04:28 AM
raptorman53's Avatar
Mine also goes past full when I top off. It also seems to go down faster on the the first half of the tank than the last half.
06 Adv. nuff said
Old 01-07-2007, 08:35 AM
Lex_Ordo
When you fill the tank, the automatic shut off will stop filling once the fuel reaches the top of the tank. I believe that the tank itself is in fact 23 Gal.
I found though, after the auto shut off, that if you very slowly fill the tank up and stop, and again, and stop, and again, etc. that the vehicle will take another 3 gallons of fuel and top off right to the top of the filler neck.
Be aware that this will take an extra 10 minutes.
As long as you're in no rush, and enjoy people watching like I do, the extra time is no bother, and plus, I leave the station with 26 gallons of fuel.
Old 01-07-2007, 01:58 PM
deserth3's Avatar
deserth3 deserth3 is offline
Interesting. If I try to add more than maby 50 cents after the first click mine starts overflowing.
Manual says 23 gallon tank. Page 5-102
Old 01-07-2007, 02:06 PM
jdrew's Avatar
i am going to drive the sucker until the light comes on and see how much it takes... the most i have ever been able to put in is 10 gallons.. and it was on 1/4 tank
Evansville, IN
H.O.P.E. Member
Old 01-07-2007, 02:19 PM
bonzaiii bonzaiii is offline
bonzaiii is on a distinguished road
Same here, I've even tried to wait for the gas in the tank to settle but it still overflows
Old 01-07-2007, 02:40 PM
You divide the miles by the gallons required to fill the tank at that time, fuel mileage has nothing to do with the maximum gallons a tank can hold.
