01-09-2007, 05:10 AM
Major Electrical problems
Sometimes it seems like my H3 has a dead battery. There are times when the remote key doesnt work and I have to use the blade key to get in. Then there are times when the remote key works but when i go to start the car nothing happens. No ignition or anything. Like the battery is completly dead. It starts working after about 5 atempts. Then for some reason my clock keeps resetting after every key cycle. Then there will be times when Im driving and I'll hear a pop coming from my speakers, like the electrical was turned off and then back on real quick.
The only mod electricaly that I have done is electronic trailer brakes. But I'v had that installed for a while now.
Anyone else have or heard of this problem??
Mercedes-benz Technician
01-09-2007, 08:19 AM
Re: Major Electrical problems
i had a similar thing happen when i was installing my radio. I was messing around with the bcm, had to use some of the wires so i had taken the connector off. I guess i hadnt snapped it in place rite. When i tried to start the car nothing. I poked around for a while and figured it out. If you messed with the bcm (the ting behind the passenger kick panel), its worth a try, but might not be it.
01-09-2007, 01:05 PM
Did you open the fuse/relay box under the hood when you did the trailer brakes?
If so the two connectors inside may not have been connected properly.
01-09-2007, 03:47 PM
You've got an intermitant OPEN circuit somewhere.. Either a loose wire in the fuse box or even a loose battery cable...
Rob
01-09-2007, 04:37 PM
 Check for trouble where you last worked and go back to mains for opens/poor conectivity.
01-09-2007, 04:44 PM
Check all your grounds too.
01-09-2007, 05:33 PM
My experience with this type of problem was a very finicky battery cable on the Ford Explorer I traded for the H3. Despite the + battery cable being tightened as much as possible, I still had the exact same problem you describe. I would have to pop the hood and wiggle the cable. And then it would start. Just a thought
01-09-2007, 05:50 PM
Same with my old truck. The combo of mud in the summer and snow in the winter caused lots of corrosion and some I couldn't see in the fibers of the cable. Whenever I had no power or reset, it was the fault of the ground not having a significant connection to complete the circuit upon start up. I was subject to constant cleaning and adjusting of cables. White vinegar works wonders. This of course would be the easiest solution, or best case scenario. Might be worth a checking before you look deeper into the electrical system.
Hybrid Mode
