02-04-2007, 06:35 AM
Superchargers and Offroading
Question for the experienced offroaders which there are quite a few in here I have noticed, I have an 03 with a magna supercharger and have yet done any serious offroading (I can't seem to get drawn for big game hunting anymore!). Anyway, a lot of threads speak of H2's with Superchargers are a death sentence offroading..
Is this based on bad technique or flat out too much torque with the weight? Most of the areas we hunt and camp in have a lot of incline and rock crawling, hate to find out the hard way the H2 is doomed. My previous vehicle was a dodge ram 1500 with a kenne bell helping out and it allowed me to crawl over about anything slowly. Appreciate the advise and love the website for information!
03 Black H2 Supercharged
02-08-2007, 03:45 AM
Re: Superchargers and Offroading
You will most likely break drivetrain parts. That is just from the way the rig was designed to be used. Slow with torque. SC kicks in sometimes a little sooner than expected and H2's factory break front end parts anyway.
some depends on driving ability. I would not run SC off-road but, others may know better. I just know how hard the SC can come on and you could have tires turned in a bind and something has to give.
TAZ
02-08-2007, 04:55 AM
Seeing you already have A supercharger installed, just be A little easier on the throttle, especially in lo lock. Use the brake and throttle together to control the torque put to the ground and you should have no problems. Carry spare front axles should be mandatory as even stock units are snapping cv's when driver error occurs. The truck and it's components will last if driven properly and not like it's indestuctible.
02-08-2007, 05:04 AM
Thanks and common sense seems to be the standard as usual. I was hoping someone would state the sc is beneficial when blowing through a mud hole but that appears to be asking for sure death......
02-08-2007, 05:19 AM
Definatly will help in A mudhole when traction is low and wheel spin is needed. "Never say Whoa in A Mudhole"
02-08-2007, 07:14 AM
Lot's of torque + sticky tires + steep slickrock + slight bounce = blown T-Case.
I know.
02-08-2007, 08:20 PM
Thats A good situation to use the brake/throttle together, when the tire bounces the brakes will stop or slow wheel spin so that nothing gets shock loaded when the tire lands. Also you can build A toe clip for your throttle pedal for better foot control in bouncy situations.
02-08-2007, 11:43 PM
I know also.
02-09-2007, 03:04 AM
I was Brake Throttle Modulating (BTM). The rear just barely bounced, not OFF the ground, the tires were still in contact with the ground, small slip and BANG!
02-09-2007, 11:46 AM
Speaking from experience the supercharger will help keep those tires spinning even when the traction control is slowing the vehicle down.
It is when you get in those situations where you have all your weight on one wheel going straight up a rock (with the rear locked) that you begin to break things. Technique? yeah probably! Will use less throttle when trying to climb from now own. Being from a mud area, I am use to pressing the throttle when your momentum slows. Not a good idea on rock with great traction (1 transmission, 2 rear axles). All on rock.
02-09-2007, 04:04 AM
Well, nothing really lives until it has bled a little.... I guess I need to get the truck dirty and hope nothing explodes like Working Hummer's.... I had a front diff blow up on me with a CJ-7 but that was from lack of torque. LOL
Hybrid Mode
