02-07-2007, 03:54 PM
Out Side Temp Gauge
Hi Everyone, I have a general question, to throw out there. The Temperature gauge on the rearview mirror, where is the sensor located on the vehicle, mine seems to fluctuate allot driving around. Could the sensor have come off and be dangling around somewhere.
Boulder Grey, Auto, Adventure Package, GOBI Stealth, TOYO 315 M/T's, Line-X Grill & Hood Vent, Sirius Radio, Sylvania Silver Stars, Zoomer's CatBack, Manik PreRunner Bar, PC Rear Spider
02-07-2007, 04:23 PM
Re: Out Side Temp Gauge
The sensor is located in the center of your H3 behind the grill in front of the radiator. Mine is currently reading -10f below actual temp. My research on this problem leads me to believe my sensor may be fouled with debris. Waiting for decent weather to give mine a good wash out. Hoping this will clear trouble...
Another side note on this problem is when changing my oil filter recently I reached forward and noticed the rubber flap that drops down when shields are removed for access. This flap when moved around holds significant amounts of road debris. Including leaves, bugs, papers & other junk not visible from view. It shakes down easily and certainly improves cooling and air flow. This could effect Temp Gauge sensor as well
02-07-2007, 04:30 PM
Thanks Wpage, that info gets me motivated to go outside and crawl around under the H3.
02-07-2007, 07:39 PM
D,
I have a suggestion (only a suggestion). You might want to make your type size 1 step bigger to make it easier to read by us old folks...
RYD (maybe zoomie also)
02-07-2007, 09:18 PM
D,
Wait he wrote something, I thought they there were dots.
02-08-2007, 04:32 PM
Thanks, I will increase my text size in all future postings.
I didn't realize it, I must be sitting to close to the monitor.
Hybrid Mode
