Old 02-12-2007, 07:47 PM
Bully13's Avatar
Bully13 Bully13 is offline
Default Air ride sensor mod made easy!
Bullies in the Garage Present:
Air ride sensor modification made easy!
So your thinking of buying 37's for your H2 but you are worried about breaking your control arm air ride sensor. Well, the Bullies are here to show you how to make it easy and affordable.
Cost of this project: 75 cents
Tools needed:
Drill,
5/16 drill bit,
Wire Cutters,
Cresent Wrench,
Monkey Wrench,
(and my personal fav...)
Henckels Brand Steak Knife
Old 02-12-2007, 07:50 PM
Bully13's Avatar
Default Re: Air ride sensor mod made easy!
The first thing you need to do is purchase two Carrage Bolts 5/16 x 1 1/4
as well as two locking nuts.
Old 02-12-2007, 07:53 PM
Bully13's Avatar
The next thing to do is to cut off the end of that pin on the control arm using a steak knife or anything else you can use to make a clean cut. (The steak knife was fast and easy. Wire cutters were a bitch)
Old 02-12-2007, 07:55 PM
Bully13's Avatar
Now it should look like this...
Old 02-12-2007, 07:57 PM
Bully13's Avatar
Now pull the arm apart like this...
Old 02-12-2007, 08:02 PM
Bully13's Avatar
Next, cut off the remaining piece of the pin using wire cutters.
