Old 11-22-2005, 02:45 AM
tomp's Avatar
tomp tomp is offline
How is it intended to be activated? Does Eaton Suggest to wire it up to activate when in 4-low as with the OEM rear locker or are you to wire it up on it's own switch?
I can see some sorta small wire harness comes with it, but now sure what that is for?
Old 11-22-2005, 10:57 PM
NJ H2's Avatar
NJ H2 NJ H2 is offline
What'd the stealership charge for the install?
Old 11-22-2005, 04:01 PM
NoMoGMPG's Avatar
NoMoGMPG NoMoGMPG is offline
After you overcome the obstacle, it is important to turn off the front locker for two reasons:
1) axle torque windup is bad, Mmmkay? Breaks stuff.
2) With the locker on you will increase your turning radius making it more difficult to make tight manuevers.
Also, don't use them on every obstacle, try to make it up using technique first, otherwise your line spotting skills deteriorate.
1) Line spotting
2) BTM technique
3) Lockers
Dave
tomp's Avatar
Old 11-22-2005, 03:29 AM
tomp's Avatar
I am the alignment Guru here, not you
Old 11-22-2005, 03:58 AM
Beastmaster's Avatar
Beastmaster is off the scale
Huh? Did I miss something here?
M101A2 Trailer
Old 11-22-2005, 02:50 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Beastmaster:
Huh? Did I miss something here? </div></BLOCKQUOTE>Yeah, just ignore me or do a search for tomp and alignment.
Old 11-23-2005, 07:37 PM
Phil, what's your reasoning for not having air suspension? Just like to get different opinions on this. </div></BLOCKQUOTE>
My guess would be the 6" lift
Old 11-24-2005, 03:39 AM
We had the air suspension on the last truck and loved it. No problems with it, ever.
With this truck we just didn't want it and couldn't justify spending the extra money since we were lifting the truck anyway.
Old 11-26-2005, 06:00 PM
tomp's Avatar
yep I have the Progressive Airtail suspension on my HD Fat Boy and have air related issues all the time. Despite that, I like the adjustability.
Old 11-23-2005, 08:54 PM
Longhorn's Avatar
Longhorn Longhorn is offline
Longhorn is off the scale
Tom- I'll give you my $.02 because you keep asking on other threads.
Some hate the air ride because they have had habitual probs with sensors and poping bags.
I personally love it. Its great when towing or when I add a bunch of weight to the rear end (gear + a hitch mounted dirt bike). It does improve clearance and departure angle when offroading. I also like the compressor for airing up tires (it does take a while to do 37s).
In 50K miles and 3+ years I have had one sensor fail. The truck was still drivable but is sagged like hell in the rear on one side. It was a 15 min fix at the dealership.
Ultimately, springs are simpler and probably more failsafe. You choose.
Old 11-23-2005, 07:23 PM
tomp's Avatar
Old 11-23-2005, 05:28 PM
VernB VernB is offline
VernB is off the scale
Thanks PhilD.
Driving around for almost a week didn't seem to harm the front locker at all. I caught it when I turned into burger king the front end hopped.
Old 11-23-2005, 03:20 AM
X2.
Last time out in Moab I hardly used my locker. I also ran Hell's from start to finish in hi range just to make it different.
BTW the OEM rear locker does not activate automatically when in 4-low, you have to push the little round button with the axel icon on it </div></BLOCKQUOTE>Alec drives too fast for 4 low anyway.
Was that "Little round button" comment meant for me?
Old 11-23-2005, 11:32 AM
Dan Dan is offline
Was that "Little round button" comment meant for me? </div></BLOCKQUOTE>
I'd say yes.
Old 11-26-2005, 06:42 PM
What kind of TIPS?
Old 11-22-2005, 03:02 PM
You want the ability to turn it on and off independent of the rear.
I do understand it's easy to f'up a front locker if used improperly. Could anyone else elaborate on that?
Old 11-22-2005, 03:15 AM
If it's a non-OEM application, you wire it up to it's own switch and rely on Mark 1, Mod Zero methods to turn it off and on safely.
Many applications put a relay in between the switch and the E-Locker just in case.
-Steve
M101A2 Trailer
Old 11-22-2005, 02:55 PM
The dealer wired and installed $1100 labor plus $300 worth of bearings. Locker was wired to it's own switch under my control. The switch that came with the e-locker was used. Dealer did not wire it to the rear elocker or T-case wiring. I've had one problem with it. It didn't unlock once, the light was off but it was still locked. I just cycled the switch and it came unlocked. I did run around a few days not knowing it was locked. I found out it was locked when mading a sharp turn and the front end hopped. H2 can still do 100 mph with it unlocked And yes I'd install it again. It will hop in the dirt also, to check if its unlocked. If I f... it up I will replace it.
A front locker cuts down on the number of times you use a winch or a tow strap.
Old 11-22-2005, 03:20 AM
You'll need an alignment before and after and during installation of any front locker.
