Old 02-19-2007, 06:09 PM
ChasH3's Avatar
ChasH3 ChasH3 is offline
ChasH3 is off the scale
Default Tie Rod
Broke one of my tie rods on the H3 doing the Odessa trail out in Calico, Ca on Saturday night..It was the Calico clean up event that was gong on out there.... Ended up getting a long bolt to thread back into the lower end, cut of the head of the bolt and bent part overlaped the bolt to the straight piece of the tie road and had someone weld it up for me. It got me off the trail and back home... It's probably stronger now then the original tie rod set-up... They used two Peterbuilt truck batteries as a power source.. You could see the jumper cables jump everytime they started welding... Will post some pictures of the fix when I can...
Old 02-19-2007, 09:02 PM
ictH3's Avatar
ictH3 ictH3 is offline
ictH3 is on a distinguished road
Default Re: Tie Rod
WOW.... nice save Chas!
Don't know of any stronger after market tie rods we could get for our 3's do ya? I'd like to get a couple spares for MOAB just in case.
2006 H3 Superior Blue, Adventure + Lux Pkg, Automatic, Sunroof, GPS, Rocker Protection, Black Brush Guard, Roof-mounted off road lamps, Trailer package, Underbody Protection, ROLA Roof Rack, and now Toyo 35's!
Old 02-19-2007, 11:52 PM
Default Re: Tie Rod
I haven't seen any aftermarket TR ends for the H3's yet. But they don't seem to be as susceptible to breakage as they are on the H2. Just carry some stock spares and you should be fine.
Old 02-20-2007, 12:37 AM
ictH3's Avatar
Default Re: Tie Rod
Thanks Sewie!!! Will Do!
Old 02-20-2007, 07:02 AM
Huck BB62's Avatar
Default Re: Tie Rod
These guys do a LOT of GM work, I betcha they'd make some up for a group buy! http://www.cognitomotorsports.com/
Old 02-20-2007, 05:17 PM
tomp's Avatar
tomp tomp is offline
Default Re: Tie Rod
See if you can get these guys to make some of their sleeves to fit. These will help retain factory warranty more over replacing them with aftermarket tie rods.
https://ssl.perfora.net/www.superdie...dex.shopscript
They look like this: http://www.trailduty.com/product_info.php?cPath=112_118_120&products_id=236
Old 02-20-2007, 10:15 PM
Khoolhandz Khoolhandz is offline
Khoolhandz is on a distinguished road
Default Re: Tie Rod
What's the GM P/N for the H3 tie rod ?
Old 02-20-2007, 10:18 PM
Default Re: Tie Rod
Depends. They changed them a while back so there's two different "kits". Have your parts dept look up your VIN and they can give you the correct part numbers.
Old 02-21-2007, 12:48 AM
Default Re: Tie Rod
And make sure to by the inner and outer (complete assembly).
Some of the first ones ordered (me included) ordered in a "complete assembly" and only got the outer.
Old 02-21-2007, 01:07 AM
ictH3's Avatar
Default Re: Tie Rod
Sorry... I didn't get the part # but my GM dealer said they were $64 & $92.
