Old 02-23-2007, 02:01 AM
vlxjim's Avatar
vlxjim vlxjim is offline
vlxjim is on a distinguished road
Default Ultimate iPod adaptor
I'm new here, I have a new 06 H2. But I did want to post over here to you H3er's I've been told that the iPod install that I did is much the same as the H3 install so this might help some of you.
I just finished installing the American International Neucleus NC-X2i in my 2006 H2. After much research I found this little gem that you could install in less than 10 minutes. With full Text and iPod function over the iPod using the radio and steering wheel controls. There are no special labels that you need for the play list like on other units out there you can also use the iPods controls as well. This is not some poor quality RF solution either. This is a high sound quality wired in pre amp level adapter. As a bonus you also get an auxiliary input that you can hook up your DVD sound to or other pre amp source to.
Here is the link to the full write up hope it helps.
http://www.elcovaforums.com/forums/s...ad.php?t=24972
06 H2 Limited SUV Pacific Blue
Old 02-23-2007, 02:53 AM
adamh3 adamh3 is offline
adamh3 is on a distinguished road
Default Re: Ultimate iPod adaptor
How much did you pay for the adapter and where did you buy it from? Thanks for the help.
Old 02-23-2007, 06:09 AM
stagger_lee's Avatar
Thanks for the info. Much appreciated!
White Collar Hippie
'06 Luxury Adventure
'99 Toyota 4runner 4x4
'71 FJ40
Old 02-23-2007, 07:57 AM
vlxjim's Avatar
As far as cost I have found them for $150 - $200 just make sure that you get it from a dealer that keep newer stock so you get the more update firmware I the unit. I found some dealers that had older units in stock. If you might tell your dealer to order you a new one.
I would not suggest the place that I bought from the guys over at A.I. said that they could give me a few good names. I well post them in the next day or so.
Old 02-24-2007, 08:49 AM
vlxjim's Avatar
Update:
A.I. has advised me that the best place to get them online is at:
http://www.logjamelectronics.com/neucncx2i.html
For $189
But this dealer always has the latest firmware.
I drove out to A.I. today (120mi) to get my unit updated with the latest firmware. It was worth it the new update is much better and fastest, there is better and more info on screen. The guys at A.I. were a great help.If you need help give Victor or Keith a call at there tech support.
http://www.americaninternational.net...sp?SubCatID=70
Old 02-26-2007, 07:23 PM
trick22 trick22 is offline
trick22 is on a distinguished road
Does anybody know if the XM module in a 2007 H3 is mounted in the same location behind the glove compartment? Thanks,
