Old 03-06-2007, 11:58 PM
tonybud tonybud is offline
tonybud is on a distinguished road
Default Wiring diagram for 05 h2 nav radio?
Im looking to hook up a couple of JL audio amps and replace the bose speakers and amp. Does anyone have a wiring diagram of the back of the nav stereo showing the color codes of what each wire is and where it goes? Would like to hook up a couple in line converters for the 2 amps. My h2 is an 05 w/ xm and onstar.
Any suggestions on which in-line converters should be used????
Thanks!
Old 03-07-2007, 10:29 PM
audiofetish's Avatar
Default Re: Wiring diagram for 05 h2 nav radio?
Make sure you don't hook up the line converters to the feeds off the back of the stereo unless you buy something like this http://www.jpcustoms.com/store/custo...cat=307&page=1. Even then, you can't disconnect the Bose amp. The line converters connect to the speaker outputs on the Bose amp in your center console. If you want to replace all of your speakers I would suggest something like http://mobile.jlaudio.com/products_c...hp?prod_id=369. This will give you aftermarket sound from your stock deck. This is a much more sophisticated version of a high/low converter. I see them on EBay for around $200 all the time. It will give you front, rear, and subs. I know there is a diagram for the amp around this forum somewhere.......
09 Challenger R/T
95 Heep Wrangler
90 5.Slow
99 HMC4 Sold
01 HMCO Sold
04 H2 Adv Sold
03 H2 Lux Totaled
HOPE Volunteer
