Old 03-19-2007, 06:11 PM
RONTENEYCK210 RONTENEYCK210 is offline
RONTENEYCK210 is on a distinguished road
Default DEAD BATTERY HELP!!!!
I have a 2004 h2 gas. Every night I park my h2 and the battery goes dead by morning. I replaced the battery and the alternator. I am sure that there are no lights on. The only item I added was a remote starting. When I disconnect the battery I do get a arch. I can not find what is drawing it down. Also when I jump the h2 to I dont have to leave the jumpers on for a long time to charge my battery, it starts right away. ANY AND ALL SUGGESTION
Old 03-19-2007, 06:38 PM
Default Re: DEAD BATTERY HELP!!!!
Take it to the dealer or the stereo shop for an accurate diagnostic test.
Old 03-19-2007, 07:16 PM
I did that, both the dealership and the sterio shop are saying there is nothing wrong. any suggestions or test I could do.
Old 03-19-2007, 10:57 PM
Did they (the dealer) check with a VAT? (Another name for a large amp meter that also checks the starting and charging system. If not, have someone check the drain with an amp meter. If there is a large drain, pull fuses until it goes away, and this will tell you the circuit that is at fault.
Also, make sure the battery cables are on good and tight.
Old 03-25-2007, 04:14 AM
Navigator is off the scale
Mine is doing the same thing, it takes 2 days. Also a 04. Dealer is 3.5 hours away, mite try local electrition.
Rich
Mods & Pics
Old 03-25-2007, 06:35 PM
we have had a few bad wiper motors, all in 04's that cuased the battery's to die in a day or so....just something else to check
Old 03-26-2007, 01:58 AM
orlasttoy's Avatar
orlasttoy orlasttoy is offline
orlasttoy is off the scale
I had a short in my remote starter that prevented the truck from starting...batt wasnt dead..but the truck showed no life...(wouldnt even attempt to turn over/no dash lites)
AND, 2 weeks ago my batt was drained by the air compressor in the rear staying on...killed the batt quick...
just my $.02
Old 03-26-2007, 01:13 PM
TXSUT's Avatar
TXSUT TXSUT is offline
There's your problem. You should have gotten the 2004 H2 diesel.
Old 05-07-2007, 12:06 PM
ppht's Avatar
ppht ppht is offline
ppht is on a distinguished road
I had the same issue. It ended up being my remote Starter. I had them rip it out and the dealer put a new harness in and I havent had an issue since....
05 Burg H2
http://picasaweb.google.com/ppht43/H2
Old 05-07-2007, 12:20 PM
mikejr's Avatar
mikejr mikejr is offline
i have heard many a remote starter draining the battery. Buddy had one do it in his monte carlo.
2009 H2 Silver Ice LE
