Old 03-21-2007, 03:22 AM
Default Hunner's Skids Install made simple
Tools, 2 jacks, 21MM deep socket with extension, gloves, safety glasses and BFH.
step one:
Clean your garage so your not on the ground in all kinds of crap!
Set your E Brake and block off your front wheels.
Old 03-21-2007, 03:24 AM
Default Re: Hunner's Skids Install made simple
Step 2:
USe each jack on either side of your the shock mount/ leaf spring hanger.
Make sure you square them up, keep the jacks just inside the edge of the shortest leaf. jack them up so the leaf pack is flat.
Old 03-21-2007, 03:27 AM
pic of above post. This will allow the the threads from the two U bolts to be long enough for you to slide the new brackets on. Make damn sure you don't let your shock push the bracket down. USe a ratchet strap to hold that in place. I just turned my Rancho shocks to one and they stayed.
Once you get the leafs jacked up safely, pull your tire. YOu get way more room. YOu may want to slide the tire under there if you don't have jack stands for a safety
Old 03-21-2007, 03:31 AM
Step 3: Go back in house and put bandage on your finger.
I did make the mistake on the first one. I let the shock push the U bolt off. Those bolts have preassure pushing outward about 1/4" It;s not easy getting them lined back up either. That's when I learned to use two jacks on the leaf springs.. (just enough room to get your plate on too).
Old 03-21-2007, 03:34 AM
It;s really an easy install if you use the two jacks. The stock shocks will no doubt be more of a challenge. You may consider taking the top of the shock mount off to make it wasier. The stock socks have more resistance then the Rancho shocks set to one.
DISCLAIMER: THese are only guidelines!!!!! If you mess up your truck or yourself, it's your fault!
...not mine.
FWIW- These thing are built strong!!!! I don;t think I've seen any skid this rigid before. I cannot wait for Moab. The otehr skids will be welded on this week sometime.
Old 03-21-2007, 03:40 AM
Once the other skids get welded on, I'll post the finished picks.
Great Job HUNNER!
Old 03-29-2007, 01:44 AM
SR1355's Avatar
SR1355 SR1355 is offline
DONE!!!!
One more item checked off the list.
Paul M
SR1355
Old 03-29-2007, 02:09 AM
Do we get to see???
Old 03-29-2007, 05:19 AM
CrisB's Avatar
CrisB CrisB is offline
Originally Posted by HummBebe
Do we get to see???
We're not takin' any more pictures 'till MOAB!!!!
All our sh!t will look better there, with red-rock scars on it.
I know you couldn't wait for powder-coating, Paul...it's on the bottom, anyway. That's what rattle-cans are for.
10 days & counting!
Old 03-29-2007, 12:34 PM
SR1355's Avatar
Do we get to see???
No time for photos, to much left to do , to little time to do it in....
See Ya in MOAB Bebe....
Paul M
SR1355
Old 03-29-2007, 01:08 PM
thats one sweet ride you got there
Old 03-29-2007, 04:46 PM
CrisB's Avatar
You don't know how bad I want to bring it, too! Gimme a V8 in an H3 & I'll tow it out next year!
Old 03-29-2007, 01:09 PM
X2
