Old 03-25-2007, 03:01 PM
Default Latest Bulletins
Various Driveability Symptoms Due to Clogged Fuel Injectors, MIL/SES DTCs P0171, P0172, P0174, P0300, P1174, P1175 (Clean Fuel Injectors and/or Perform Injector Test With AFIT - CH-47976) #03-06-04-030C - (03/15/2007)
ALL GM Vehicles.
Condition
Some customers may comment on any of the following various driveability symptoms:
? Extended Crank Time
? Hard to Start
? MIL/SES Illuminated with DTCs:
? Hesitation
? Lack of Power
? Surge or Chuggle
? Rough Idle
? Light or Intermittent Misfire
Cause
Due to various factors, the fuel injectors may become restricted. Extensive testing has demonstrated that fuel related issues are the cause of clogged injectors. At this point, no specific fuel, fuel constituent, or engine condition has been identified as causing the restriction. The restriction causes the engine to operate at a lean air fuel ratio. This may either trigger the MIL to illuminate or the engine to develop various driveability symptoms.
Old 03-25-2007, 05:27 PM
Huck BB62's Avatar
Default Re: Latest Bulletins
Timely post! Thanks. My H3's in the shop with the cursed rear end problem yet again and I just recently had a drop in mileage and it idles rougher. I'm not having any codes though. I'll be calling first thing Monday morning.
Chuggle, is that a technical term? I gotta remember that one!
Old 03-25-2007, 06:05 PM
Good to know. I only use Chevron gas in all 3 of our vehicles. So far so good.
Old 03-25-2007, 06:31 PM
is that measured in secinds or miliseconds?? i always get that mixed up.
Old 03-25-2007, 08:43 PM
What rear end problem? Are you having problems with the rear diff?
Old 03-26-2007, 06:49 AM
Huck BB62's Avatar
Well, they think so. It's got the same symptoms as when the coil burned up in the elocker. It's still there, I'll post their findings. The passenger side inside door handle also cracked to smithereens in the bitter cold this winter. Looks like someone took a razor knife to it!
Old 03-26-2007, 12:07 PM
Dani Dani is offline
Dani is off the scale
Get used to it. I'm on my 3rd or 4th passenger door handle already. I lost count
If the broom fits, fly it!
Old 03-26-2007, 10:48 PM
Are the repairing or replacing? With that many trips back, I would yell for a complete new assembly. Almost sounds like the tech is not doing something correctly.
Old 03-26-2007, 11:12 PM
Huck BB62's Avatar
Well, here's my dream world: The rear end does ok and grenades this fall when they can lemon it out and I'll get the Alpha! (just kidding, but replacement's what I have in mind.)
Old 03-27-2007, 01:56 AM
SnakeH2's Avatar
SnakeH2 SnakeH2 is offline
Originally Posted by f5fstop
ALL GM Vehicles.
Condition
? Hard to Start
? Hesitation
? Lack of Power
? Surge or Chuggle
? Rough Idle
Doesn't everyone complain about that?
Where's WiFey?
