Old 04-03-2007, 05:22 AM
mrlittle's Avatar
mrlittle mrlittle is offline
mrlittle is on a distinguished road
Default New speakers for h2?????????????
I have changed out my stock head unit with an eclipse unit and I kept the stock amp and speakers.I want to change out the speakers only can I do this? Which type of speakers are good and what size are they for the H2?
I have seen the componet speakers if i get those do I have to install those crossover things and if so were do you guys put them....
Any help will do thanks.......
Old 04-03-2007, 01:41 PM
mrlittle's Avatar
Default Re: New speakers for h2?????????????
nobody changed there speakers ?
Old 04-03-2007, 02:38 PM
H2 OHHH!'s Avatar
H2 OHHH! H2 OHHH! is offline
H2 OHHH! is on a distinguished road
I switched mine out w/ JL Audio 6.5" componets in the front, 5.25" in the back and eliminated the two in the very back. Also switched out the tweeters up front. If you are going to put quality speakers in you may as well put in a good quality amp. Then you'll realize that another amp and a 12" stealth box are needed.
Old Chinese Proverb "Man who walk through airport turnstile sideways going to Bangkok"
Old 04-03-2007, 04:08 PM
wingnut2u's Avatar
wingnut2u wingnut2u is offline
wingnut2u is on a distinguished road
I changed mine out to MB Quart PCE-216's, added a JL Audio 450/4 amp. You will not be totally happy unless you upgrade the sub as well. The sub is what truly makes the difference in the upgraded sound, I went with a JL Audio 12w7 sub and a JL Audio 1000/1 amp, in a custom sub box to clear up some room in the rear cargo area. My set up is probably a little overkill for most but it does sound marvelous.
Old 04-03-2007, 04:10 PM
wingnut2u's Avatar
amps
Old 04-04-2007, 09:01 PM
Question Re: New speakers for h2?????????????
can you guys tell me where the factory amp is located?
does anyone have the amp's size?
is it a 4, 5, or 6 channel amp?
does anyone know what kind of output this thing is putting out.
thanks
i used the search button, but nothing came up.
2006 Yellow H2 Lux Series
Cognito Steering Support Kit
Cognito Idler Pivot Kit
Fabtech Steering Stabilizer
Fabtech Tie Rods
Power Slot Slotted Rotors
Hypertech Power Programmer
True Flow Foam Air Filter
Old 04-05-2007, 02:05 AM
Motohead's Avatar
Motohead Motohead is offline
I have Rockford all around. Components up front, Crossovers are mounted in dash, but can also be mounted inside of doors. Left factory amp/sub for a little extra midrange, why not. Had a custom box made for the SUT that has 2 Rockford 8's.
Old 04-05-2007, 02:02 PM
genob genob is offline
genob is on a distinguished road
I really like that panel that's mounted in the back... How much for something like that?? It's soooo f'in clean looking!
g
