05-09-2007, 09:19 PM
Tire Pressure for 35" tires?
What should a 35" tire be inflated to for normal road driving? I have Coopers and on the tire it states that cold the max psi should be 50. I have them at 40psi now and go down to about 20 or 25 when offroad. Any suggestions.
The Goat
05-09-2007, 09:39 PM
Re: Tire Pressure for 35" tires?
Read the tire placard at the driver's door. Max air pressure and recommended are two different things.
05-09-2007, 10:35 PM
I've always wondered about that - What if they aren't the original tires that were on the car. What if you go bigger and better - do you still fill to what it says inside the door??
05-09-2007, 11:30 PM
no guys, you fill what is says on the TIRE. Every tire has it written on it.  Every tire has the PSI, the Size, and brand and whatever information is needed. Just bend down, take ur glasses off and read the tire itself. I cant be any clearer
2007 Black H3, Adventure Package, Chrome Appearance, Chrome Cross Bars, Moonroof, Tow Package, Chrome Tubular Assist Steps. "My golly, this is by far the best looking 2007 H3 you will ever never witness"
My H3 is gods gift to man.
05-09-2007, 11:34 PM
Isn't that MAX psi shown on the side of the tire? (not recommended psi)
05-09-2007, 11:44 PM
actually I do think your right. I may have been mistaken.
05-10-2007, 03:34 AM
Um buddy, I believe you apparently started out wrong....and then ended rudely.
05-10-2007, 04:00 AM
If you look in the driver door of an H2, you might get your answer.....
38 psi.....and that's what I run at.
05-21-2007, 09:22 PM
Oui vey.. Yall are violent today..
I'm running 45psi in my 35" BFG MTs Air down to about 19 - 20 PSI
Rob
05-22-2007, 12:26 PM
Originally Posted by NOMOYELLO
OUI VEY!!!WITH ALL THAT PSI YOUR HEAD IS GONNA POP.....
Really..?? The tires have 45 Max PSI recommended stamped on the side of them I believe.. And I've heard of folks running 50 in them..
Rob
Hybrid Mode
