Old 11-07-2005, 08:56 PM
theadlee theadlee is offline
theadlee is off the scale
f5fstop,
Since your are the guy with all answers, Do you have some documentation demonstrates how to get at the stock XM Radio above the glove compartment. I removed the glove compartment door, but that doesn't get me all of the way there.
The reason I am asking is that I want to use the stock XM Radio antenna on my pioneer XM Radio receiver.
Thanks for your help.
f5fstop,
Old 11-07-2005, 09:11 PM
Remove the instrument panel (I/P) compartment door. (5 screws)
Remove the right I/P outer trim cover (cover on the end of the I/P). (Two pushpins under where the door closes, then it is held in place with some plastic retainers. Just grip and pull...after the two pushpins are removed.)
Unfold the service panel located above the I/P compartment door.
Remove the screws retaining the digital radio receiver to the I/P structure. Then remove receiver.
DO NOT PRY or slide the electrical lever release, just press it to release the large connector with two wires (I believe two wires).
For the other connector, remove the connector position securing device, then remove the connector.
Old 11-25-2006, 09:13 AM
comph
Default Re: XM Radio access??
Sorry for jumping in, but I have the same problem, and would appreciate some clarifications. By I/P compartment door, do you mean the glove compartment door? Is the service panel the airbag panel? How do you unfold it, by pressing from behind the I/P? I am sorry if these are simple questions, but I don't want to break anything. Thanks.
Old 01-28-2007, 08:29 AM
The answer was right above you. You're just excited to be here.
Old 01-28-2007, 02:13 PM
Wu Jen's Avatar
Wu Jen Wu Jen is offline
Wu Jen is on a distinguished road
I was also thinking of replacing my stock head unit with a Pioneer Z2 system, but is it compatable with the XM unit already built into my vehicle? I know sometimes manufactures like to use proprietary connectiors/signals and such. Thanks again!
2007 H3 Midnight Blue, Adventure pkg
Old 01-28-2007, 02:44 PM
The Z1 required the Pioneer XM unit; can't speak for the Z2 since it is not out yet, but I would bet it will require a pioneer XM.
Old 11-25-2006, 02:09 PM
Remove the instrument panel (I/P) compartment door. (5 screws) - AKA; Glove box door
Remove the right I/P outer trim cover (cover on the end of the I/P - this is the cover the door closes against that is one the end of the I/P). (Two pushpins under where the door closes, then it is held in place with some plastic retainers. Just grip and pull...after the two pushpins are removed.)
Unfold the service panel located above the I/P compartment door. After the door is removed, look up and you will see a flap type panel, just fold it back IT IS NOT AN AIR BAGRemove the screws retaining the digital radio receiver to the I/P structure. Then remove receiver.
You are not messing with the air bags, you are below the air bag. If you see any YELLOW connector do NOT touch or disconnect; that will be an air bag connector.
