01-20-2006, 11:28 AM
I found these on ebay, does anyone have any experience w/ either? Any other suggestions? Thanks.
$400 one
$260 one
Semper Fi,
Michael
$400 one
$260 one
Semper Fi,
Michael
01-20-2006, 12:25 PM
I would skip the kits and build your own system for two reasons.
1. I don't like the setups where the compressor is attached to the tank. You're going to have a hard enough time finding a place to mount a tank, much less one with a compressor hanging off it.
2. You need at least a 3 gallon tank to power those horns. I have similar horns and they use about 75cfm.
The key to air horns is not so much the pressure, but the air volume. If you want to get the full effect of the horns you need to go with BIG tank ports, air line, and valve. I used 1/2" for everything and it made a HUGE difference over the crappy 1/4" line they give you with a kit.
I wasted a bunch of time and $$ figuring this out. If I had to do it again I'd buy the stuff separately:
Horns
3-gal tank with 1/2" ports
ViAir compressor
150psi pressure switch
1/2" I.D. hose
1/2" I.D. Valve - I used a GC Xtreme fast nitrous valve
That will get you the most from the horns. A couple second blast will drop the 3-gallon tank down 50psi and take a minute or two to refill. I can take a few pics of my setup if you're interested.
Have fun!
01-20-2006, 12:50 PM
The Viair is the only option of those two but follow Dan's advice. The Viair's compressor is a 100% duty compressor so you don't have to worry about it running all the time and wearing out if you set up the air as on-board air for tires, tools, etc.
You'll have a much easier time trying to fit a tank of that size somewhere. I have 5 gallon tank and it will not fit anywhere within reason.
Buy the components separate and find a tank with at least one 1/2" port.
01-23-2006, 02:39 AM
I have basically the same kit as the 260.00 one ill sell you the horns and compressor for less and theyre brand new still in the boxes.
01-20-2006, 02:04 PM
Awesome, thanks Dan!
Semper Fi,
Michael
01-22-2006, 08:39 PM
Here ya go, here is the horn installation. If you want a compressor/tank pic let me know. It's pretty much self-explainatory though.
01-23-2006, 01:03 PM
Here ya go, here is the horn installation. If you want a compressor/tank pic let me know. It's pretty much self-explainatory though. </div></BLOCKQUOTE>
Man, that's tight in there under the hood. But it is out of view so it won't draw the attention of a LEO looking for any excuse to hassle you.
'03 pewter base H2
01-20-2006, 01:55 PM
Dan, can you post some pics of your new setup (or email them to me)? I have an SUT also, so I'd like to do something simliar to your setup. Thanks for all the helpful info guys. Semper Fi!
Semper Fi,
Michael
01-23-2006, 02:47 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by WhiteH2Kid:
I have basically the same kit as the 260.00 one ill sell you the horns and compressor for less and theyre brand new still in the boxes. </div></BLOCKQUOTE>Covered by insurance?
01-20-2006, 12:28 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by ree:
Take a read through this thread:
http://elcova.com/groupee/forums/a/t...7321083621/p/1
There's a bunch of opinions/experiences posted there. Dan's got some detailed pictures and commentary on his kit install. </div></BLOCKQUOTE>
Yeah, those were the early stages. I still have the same horns & compressor in the pics, but I have a different tank, line, and valve now.
01-23-2006, 02:45 AM
can you post pics of where you put the compressor and tank as well please..
01-23-2006, 01:00 PM
can you post pics of where you put the compressor and tank as well please.. </div></BLOCKQUOTE>
Here is where the tank & compressor are. The pic is a little old, I have a different tank now. Same setup though.
01-20-2006, 12:13 PM
'03 pewter base H2
01-20-2006, 02:22 PM
Few things - I made my own bracket for the horns by welding angle iron onto the existing bracket. You'll have to do something similar if you want them under the hood. It's a very tight fit but it can be done. Also, I have the compressor & tank mounted in the jack compartment in the bed. The jack is now under the back seat.
The the jack compartment you'll need to grind/cut off the jack mounts so the tank will fit. I had to cut some of the plastic between the compartment and where the accessory outlet is since the tank was long. The compressor power is tapped into the accessory outlet power.
I'll post more as I think of it.
I'll take some & post them here. I'll try to do it tonite or tomorrow AM.
Hybrid Mode
