Old 11-30-2005, 01:40 AM
Field Rat's Avatar
Field Rat Field Rat is offline
Field Rat is off the scale
I have a chrome piece over the rear tag. I would like to have a black part. Can anyone help. Anyone want to trade? No jokes please!!
\'97 H1 Green Soft Top SOLD
\'03 H2 Pewter SUV= SOLD
\'05 H2 Desert Sand SUV
\'05 H2 Stealth Gray SUV
Old 11-30-2005, 02:28 AM
Field Rat's Avatar
Also, that is attached to an Hummer H2 made by GM.
Old 11-30-2005, 04:16 AM
I'm glad I saw this because that part was bothering me all day... what to do... what to do...
Field Rat's Avatar
Old 11-30-2005, 01:52 AM
I think it should be "part want" - you don't really "need" it per say.
There was a priest, a rabbi and a black part...
Old 11-30-2005, 02:06 AM
Field Rat's Avatar
You should not be talking, you have had a lot of black parts.
Old 11-30-2005, 04:35 AM
Take the rear tag assembly off the tire, flip it over and you'll see four clips that hold the chrome part on. Remove the clips, remove the chrome.
Rough up the chrome with some fine grit sandpaper then shoot it with a few coats of Plasti Dip, which you can get at Home Depot or Lowes. It will match the black finish of the license holder perfectly.
</div></BLOCKQUOTE>
Doesn't that stuff peel off relatively easily?
Old 11-30-2005, 03:53 AM
rodster rodster is offline
rodster is off the scale
\'05 SUT
Old 11-30-2005, 05:00 AM
Doesn't that stuff peel off relatively easily? </div></BLOCKQUOTE>
So far so good. I've pressure washed it and it's been in the Vegas sun. That said, I don't put many miles on the truck so I guess time will tell.
One thing I did that I think helped was I shot the front and turned the corner and partially painted the back. The idea was to not have a loose edge exposed.
\'05 SUT
Old 11-30-2005, 02:26 AM
Field Rat's Avatar
Yea, you got me. I would like to know if anyone out in hummerland has the black part (part number and name unkown) that the rear license plate is attached to, and that the license tag light is affixed, available. Is that better?
Old 11-30-2005, 02:03 AM
He wants a black "part". Mudshark.
Ask GMpartsguy. ...black "part.
Old 11-30-2005, 02:46 AM
VTSTOMPER is off the scale
you can see TXSUT's here:
http://elcova.com/groupee/forums/a/t...1/m/7231019241
'05 Stealth Gray SUT
A Mellow Mix of Black & Bling
Old 11-30-2005, 02:23 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Field Rat:
You should not be talking, you have had a lot of black parts. </div></BLOCKQUOTE>
On my H2. The difference is that you asked for a black "part".
Old 11-30-2005, 04:18 PM
dochummer's Avatar
I used to have a chrome piece, I had the dealer switch it out under warranty and replace it with a black one...It was loose and scratching the paint.
'03 H2
Old 11-30-2005, 01:57 AM
Field Rat's Avatar
How about, item wanted?
Do you have what I need?
Old 11-30-2005, 02:40 AM
rodster and TXSUT have plastic dipped their chrome brows. Ask them how - it is like rubber coated.
PS: I think factory is silver or chrome only.
Old 11-30-2005, 05:12 AM
Hmmm... Sounds good. I do use PlastiDip on all kinds of stuff. Good to know that it stands up to pressure washing. If my mirrors start chipping I'll redo them with that stuff.
