Old 05-21-2007, 02:32 PM
Woogy's Avatar
Woogy Woogy is offline
Woogy is off the scale
Default XM Radio Help
I have recently installed a gobi rack on my H2. Now my XM satellite radio reception is crappy. I am sure its due to the wind deflector. So, my current thinking is that I can mount a new XM antenna to the XM receiver and route the antenna to a clear spot on the back on the truck.
Here is the issue: Does anyone know how to mount an aftermarket XM antenna to the existing XM receiver? Based on the antennas I have seen the plug looks completely different.
Any thoughts would be appreciated.
Thanks,
W
Old 05-21-2007, 03:52 PM
MattRoberts123 MattRoberts123 is offline
MattRoberts123 is on a distinguished road
Default Re: XM Radio Help
Usually all XM antenna plugs are the same. Most of the time the different companies will put little colored plastic tabs on them that prevent you from hooking up a different company antenna to their unit.
All you have to do USUALLY is remove the aftermarket plastic piece that they put on there. Then TYPICALLY the antenna plug is iddentical once you get that piece removed.
Granted, this isn't always true, but hopefully in your case it is and will work.
-Matt
Carless... riding the bus... Trying to decide on which 08 H2 to get
Old 05-23-2007, 02:02 PM
Woogy's Avatar
Got it. Pull the little plastic cover off and it worked like a charm.
Thanks,
W
Old 05-23-2007, 02:52 PM
MarineHawk's Avatar
Are you sure about the cause and effect? You are aware of this, right?: http://www.foxnews.com/story/0,2933,274693,00.html
Old 05-23-2007, 09:06 PM
johndjmix1's Avatar
johndjmix1 johndjmix1 is offline
johndjmix1 is off the scale
Be VERY careful with the XM antenna wire......its about as fragile as fiber optic cable.....if you kink it somewhere it will break inside and stop working.
--John
2006 Hummer H2 Lux Series
www.JohnHasMoreFun.com
1/4 Mile 15.29@91.34mph
Mods:
Warn 9.5 Winch
Old 05-23-2007, 09:16 PM
XM is having sat problems, signal has been decreased! MAY HAVE NOTHINGTO DUE WITH YOUR UNIT!
Problems Solved?
XM's technical issues (NET NEWS 5/21) continued through this morning, but have begun to clear this afternoon. The following notice is currently posted on XM's website:
XM Radio Resumes Normal Levels of Service
XM Satellite Radio has resumed normal levels of service for customers who experienced outages or significantly degraded service starting yesterday.
The problem occurred during the loading of software to a critical component of the satellite broadcast system, which resulted in a temporary loss of signal from one of the company?s satellites.
After you turn on your XM radio, please allow five to ten minutes to reacquire the XM signal.
XM apologizes for any inconvenience this has caused.
this is ongoing so don't belive it will be fixed in one day
Old 05-24-2007, 01:11 AM
Woogy's Avatar
Thanks for the input. I was aware of the outage and my issue is about 3 months old (ever since I added the Gobi).
The existing wire seems to be safe.
Thx
W
