Old 06-05-2007, 02:18 AM
joedirt's Avatar
joedirt joedirt is offline
joedirt is on a distinguished road
Default WTS: 5 Chrome OEM Wheels w/o Tires
Yep! I have the 5 factory chrome 16x7 wheels without the tires and TPMS Sensors. I had put less than 9K miles on them. They are in perfect condition with no curb damage and were never offroaded on...maybe some light dirt scratches from washing. The dealer charged me $900 extra for the chrome OEM. Can post some pics later if needed. Make me an offer.
07 H3/ Slate Blue/ Adventure Package
Old 06-06-2007, 04:11 PM
DrBill DrBill is offline
DrBill is off the scale
Default Re: WTS: 5 Chrome OEM Wheels w/o Tires
Would these fit directly on my new 2007 h3 (luxury) with existing 16" wheels/tires- and can i just mount my existing tires on your wheels? TPMS- Would that be an issue as well?. let me know and will make an offer...TIA
Old 06-06-2007, 08:14 PM
joedirt's Avatar
They will fit no problem. This is a standard size for the Base model and the Adventure, only difference is AT tire and Passenger tire. The TPMS sensor is as easy as removing the tire and unscrewing the sensor to put on the new rim. I paid $900 for them from the factory. They have a factory warranty on the chrome. Here are the specs. I have included a picture of the design. What is your tire size?
WHEELS SIZE: 16"X7.5" , 6 x 5 1/2" BOLT PATTERN WITH 38MM OFFSET
Old 06-07-2007, 03:38 AM
i have the stock 16"wheels- the tire size is P265/75R16 goodyear tires, alloy wheels.Tpms sensor is just unscrewing and rescrewing? $900 for all 5, correct? the design of your wheels is different then my standard alloy wheels...will my tire size fit your wheels? if so will give offer....
Old 06-07-2007, 04:48 AM
joedirt's Avatar
The only difference is in width. My tire is about 3/4 of an inch wider than yours. The rims are 16 inches tall x 7.5 inches wide. Your tire is almost 10.5 inches wide...no problem for fit. The TPMS sensors are that easy to change out. I put mine on my 20 Inch Helo Maxx wheels with ease (No trouble Code experienced on dash after change). Here are the specs from the Discount Tire calculator. Your design wheel, I am sure, is with the solid bar instead of the spoke - like the H3x wheel. My H3 is also a 2007 Lux Offroad, but I purchased mine at the end of 2006.
Results
Tire 1: 285/75/R16
Tire 2: 268/75/R16
Sidewall Height:
...(In Inches)
Tire 1: 8.42
Tire 2: 7.82
Section Width:
Tire 1: 11.22
Tire 2: 10.43
Overall Diameter:
Tire 1: 32.83
Tire 2: 31.65
Old 06-14-2007, 07:41 PM
H3slate's Avatar
H3slate H3slate is offline
Are these still available?
