06-14-2007, 07:33 PM
remote start
Anyone installed one? DO you know if there is one that is just added unit to existing GM security system?
06-14-2007, 08:59 PM
Re: remote start
Mine works as just a remote starter and does not interfere with passlock systems.
06-15-2007, 06:10 AM
Re: remote start
I had a code alarm 2 way security system, keyless entry and remote start installed in my H2 a week after buying it. Love the remote start and being able to light her up walking up in the dark. Plus its cool when I get in cuz the a/c has been cranking for a few minutes. About 320 bucks installed.
07 H2 with lots of bling... well, have some..more coming
06-15-2007, 08:30 AM
Re: remote start
I just upgraded to the Compustar Pro P2W9000FMR. It's COOL!! The tech at my HUMMER dealership set it so when I start it in the winter, the heated seats come on!! Around $600 installed.
http://compustar.org/
Up to 3000* feet of Range
This new CompuStar Pro 2W9000FMR remote has a built in clock, in-vehicle temperature readout, and battery voltage sensing. This system operates at a higher frequency to allow for greater range and battery life. Firstech engineers were the first to perfect 900MHz FM for vehicle security applications and we've taken this technology to the next level with the 2W9000FMR Pro.
*Range is quoted for U.S. models only. International models will differ in range.
Includes 1 x Two-Way and 1 x One-Way remote
View the manual for the P2W900FMR
Pro Remote Features
- Two-way paging remote
- New multi-color LCD (liquid crystal display)
- CompuGlow backlight
- Vibration and audible notification
- Clock display with alarm
- Internal vehicle temperature display
- Parking Meter timer
- Button lock
- Timer Start Mode
- Cold and hot starting with temperature
- Run-time indicator (extendable with remote)
- Turbo Timer (extendable with remote)
- Secure Auxiliary Mode
- Shock sensor on/off through remote
- Passive mode on/off through remote
- Valet mode on/off through remote
- Uses standard AAA 1.5 volt battery
Pro Alarm Features | P2W9000FM-A
Pro Starter Features | P2W9000FM-S
Pro Alarm/Start Features | P2W9000FM-AS
- Includes starter-kill relay
- Battery backup capable
- External Siren (six-tone)
- Optional super bright blue LED
- Driver's priority unlock
- Ignition controlled door locks
- Includes dual stage shock sensor
- Secure valet switch
- Anti-Jacking mode
- Remote Paging System (can unlock vehicle via pin code)
- 2-auxillary outputs, expandable to 7 with Channel Expander
- 2-programmable inputs
- Selectable trunk release output
- Horn trigger output
- Includes anti-grind and starter-kill relay
- Factory Style Alarm, monitors doors and trunk
- Time start set on remote by user
- Optional external Siren (six-tone)
- Diesel timer built-in
- Manual transmission compatible
- Anti-Jacking mode
BLACK \'04 H2 LUX
BLACK \'07 ESCALADE
06-15-2007, 02:26 PM
Re: remote start
Pro Remote Features
- Button lock
- Timer Start Mode
- Anti-Jacking mode
- Anti-Jacking mode
i have the same 1......works real good
06-15-2007, 02:47 PM
Re: remote start
great systems, you will love this one...
Hybrid Mode
