06-27-2007, 04:49 PM
2500HD Fan Part Numbers
Does anyone have all the part numbers that need to be ordered to convert the H2's clutch fan over to the 2500HD electric fan? I think I recall reading you need to order everything seperately (fans, shroud, nuts/bolts) and I found the wiring harness at Nelson Performance so I'm good there.
Thanks in advance,
Dan
06-28-2007, 08:43 AM
Re: 2500HD Fan Part Numbers
Partsguy and I have covered this many times so you may be able to do a search and find what you need on forum already.
Yesterday I responded to question Orange was having about using a shroud or not and mentioned parts needed and to contact Nelson on buying harness to match HD fan kit. I'm sorry i cannot recall the parts numbers.
I'm not sure how it applies past 2005 H2's or if numbers can be gotten vey easily anymore. I do know they have been mentioned a long time back in our forum. Search may turn them up.
Sorry for not being more help.
TAZ
06-28-2007, 09:46 PM
listed as chevrolet parts:
shroud: 89023365
motor: 89023368 [need 2]
Blade: 89023366 [need 2]
if you need the connector: 88987983 [need 2]
06-29-2007, 01:13 AM
Is this a "plug-n-Play" setup, meaning there are connections in the H2's wiring harness to support these two connectors?
06-29-2007, 04:27 AM
Thanks guys...I did several searches and couldn't find any part numbers.
06-29-2007, 07:53 AM
The GM HD fan kit has to have wiring harness from Nelsonperformance.com
It will come with info on connections.
TAZ
06-29-2007, 04:29 PM
Me, Too.
Hybrid Mode
