Old 06-28-2007, 03:46 AM
Tallowood_Air's Avatar
Tallowood_Air Tallowood_Air is offline
Tallowood_Air is on a distinguished road
Angry Jumping Belt
Finailly got the 2.8" pulley put on - and a belt that's an inch shorter. Now the belt jumps off the pulley. WTF?
look at this.
what do you think?
2007 SUV LUX All-Terrain Blue
Polished Radix Magnacharger; 2.8" pulley; Tuned by HESCO; Custom 4L80E "Raptor" by PACT
GM 2500HD Efans on SPAL controler; K&N filter element; Dynatech Headers + Cats; Magnaflow cat-back
37" Kumho Road Venture MT KL71 on 24" ZINIK Mazotti
Pioneer AVIC-Z1 HDD navigation; 2 x 12" JL W6; Custom Box w/ Lights
Old 06-28-2007, 04:03 AM
ttkresurfacing's Avatar
ttkresurfacing ttkresurfacing is offline
ttkresurfacing is off the scale
Default Re: Jumping Belt
I think it's pretty common when you pulley down that much. You might want to check into Metco 100mm idler pullies. They give you quite a bit more wrap. Did you retune for the new pulley? Have any idea on your new boost?
Tim
Old 06-28-2007, 07:21 AM
tuned by hesco in birmingham, AL
7 psi at most on a hard pull.
better wrap than this?
Old 06-28-2007, 08:22 AM
Check alignment of your idler pulley. Most likely the problem. It does not seem like it would be a problem. If the SC pulley is a little forward of the idler pulley the belt gets onto the front edge of idler which is slightly tapered on front edge and when belt gets to running on the front edge it will just keep working the belt off.
Did not have this problem myself but, have helped a few others with the tip. I also had the problem occur on my 1999 Silverado and just drove me nuts till i really checked alignment of all pulleys.
Hope this helps with problem. If this is not the trouble i would not know where to go from here. On my 99 Chevy Silverado I had added a higher amp altenator which made me go to a longer belt. The new altenator sat a little forward of the old one. I figured out the pulley alingment is critical especially in a higher rpm situation as is with the belt needing to spin SC faster.
Sorry for the long way around to a really short answer but, like to explain what i have learned in case someone else had similar problem with say just a car as the problem could apply there also.
Good Luck!!
TAZ
Old 06-28-2007, 08:52 AM
what bugs me is that it ran perfectly for 5 months, then the only thing changed was the nose pulley, now it jumped off...
Old 06-28-2007, 10:47 PM
H2 Bill H2 Bill is offline
Was there a spacer behind the pulley? In the picture it looks as to the pulley is really close to the S/C. Did you put it on backwards perhaps? I has to be an alignment problem.
1994 Chev Suburban Blown
