Old 06-28-2007, 04:52 PM
H3.007 H3.007 is offline
Question Rear Fender Removal
For all of you H3ers that have intentionally (yes - INTENTIONALLY ) removed your rear fenders for painting, chip proofing, or other mods, how'd ya do it? Which screws, blots, or bubble gum pieces did you unfasten tor emove the fenders?
Thx!
Old 06-28-2007, 05:21 PM
Default Re: Rear Fender Removal
First you need to remove the inner fender well.
There are retainers that you will need a medium sized flat head screwdriver to pop out the center of the retainer. The causes the body of the retainer to collapse so it can be removed.
When you have the liner out you can look up under neath and see the attachment area. Gently pull the fender away from the body. I used a long pair of needle nosed pliers that are curved at the end, to gently squeeze the clip which releases the fender. IIRC there are about 5 or 6 clips from front to back.
If you break a clip you can get them from the dealer, pretty cheap, HOWEVER, the rear clips come with a fender. Ask for the clips for the front fender, they work just fine for the rear too.
Old 06-28-2007, 05:46 PM
it's all snap on man
Old 06-29-2007, 02:39 AM
deserth3's Avatar
deserth3 deserth3 is offline
One of the original H3 designes called for the fenders to be easily removed for offroading. Didn't quite make it into the final design.
Old 06-29-2007, 02:42 AM
Thanks Hummbebe and everyone else for the responses!
Old 06-29-2007, 02:50 AM
deserth3's Avatar
If you remove them, we want pictures.
OK, Maybe just I do.
