07-06-2007, 03:46 PM
Clunk noise over bumps
Whenever I run over a bump, such as a speed bump in a parking lot, at any speed over a snail's pace, I get a pretty loud "clunk" as the front suspension rebounds (extends after having compressed from the bump). I have my torsion bars cranked to level the truck, so could this noise be coming from the shocks, as they run out of extension travel?
Thanks,
Pete
07-06-2007, 03:55 PM
Re: Clunk noise over bumps
Try shock extensions or longer Cognito shocks. Will make a big improvement in ride quality, if it doesn't fix the clunk.
07-06-2007, 04:57 PM
Thanks for the advice, but I'd like to know first if lifting the front of the truck by a couple of inches via the torsion bars is enough of a change that you run out of shock travel on something as small as a speed bump.
07-07-2007, 02:20 AM
Not sure if it's what is causing the clunk. Might take it to dealer and let them take a look.
07-06-2007, 09:47 PM
Would those not lift the truck to some degree?
No
07-07-2007, 11:46 AM
I agree that it's the shocks. Most shocks only have about 2 inches of "play" in them. I've had this happen on a Grand Cherokee I used to own.
2008 H3 Alpha - Boulder Gray
07-07-2007, 04:28 PM
Check your skid plate - make sure it's tight and there aren't any rocks wedged in it. Make sure all of your grease points are full. If it still makes noise have the dealer check all of the front suspension components.
07-08-2007, 01:13 AM
Thanks,
Pete
my truck started doing the same thing after cranking the torsion bars. however, i plan on getting shock extensions or upgrading to longer shocks...hopefully that will fix the problem.
2003 Hummer H2 LUX...sold
2006 Hummer H2 SUT LUX...sold
2018 Polaris GEM e4
2022 Can-Am Maverick X3 XRS Turbo RR
2024 Rivian R1S Adventure
2024 GMC Sierra AT4X HD
2024 GMC Hummer EV 2X SUV
07-08-2007, 03:56 AM
When my truck did that, it was loose control arms. Check your upper and lower CA's and both bolts on each arm.
07-09-2007, 05:03 PM
Thanks guys, appreciate the help.
Hybrid Mode
