Old 07-11-2007, 01:13 AM
Tallowood_Air's Avatar
Tallowood_Air Tallowood_Air is offline
Tallowood_Air is on a distinguished road
Cool stop calling me out!
well after the millionth person called me out on not having the matching wheel on the back, I finally put the 5th 24" on.
cut some off.
added a stud.
used four 3/4" nuts for a spacers
I like to use all spline-type lugs so they're easier to start down in the seat
ta. da.
2007 SUV LUX All-Terrain Blue
Polished Radix Magnacharger; 2.8" pulley; Tuned by HESCO; Custom 4L80E "Raptor" by PACT
GM 2500HD Efans on SPAL controler; K&N filter element; Dynatech Headers + Cats; Magnaflow cat-back
37" Kumho Road Venture MT KL71 on 24" ZINIK Mazotti
Pioneer AVIC-Z1 HDD navigation; 2 x 12" JL W6; Custom Box w/ Lights
Old 07-11-2007, 01:37 AM
H3slate's Avatar
H3slate H3slate is offline
Default Re: stop calling me out!
Nice rear end!!
I like those tires!!!
Old 07-11-2007, 05:21 AM
jmsspratlin's Avatar
I not one of the ones that called, however I am doing the same thing at the moment. I am just waiting on the tag/hitch to come in. Thanks alot for the pics....Jamie
Old 07-11-2007, 05:24 AM
Also, did you add the extra stud for pure support? Were 3 not enough? Also, why the 3/4" nut in the back for the spacer, and can the cut be made with a Dremel tool? Thanks....Jamie
Old 07-11-2007, 09:22 AM
the stud is for support, I'm not sure it needs it, but it really wasn't all that hard, so why not? I used a 9/16" bit to open up the little hole for the stud. Then i used a dremel to open it up a little more, then hammered the stud in from the back.
If I hadn't used the spacer, because it has a different backsacing, it would have sat crooked. I guess I used a nut for a spacer because it's better than a stack of washers.
You can eventually cut anything with a dremal, but I used a reciprocating saw to cut off the support. [that mild steel frame cut like butter] As for how much to cut off; put your wheel up there and mark the most you can leave and still put on the center cap. You don't want to try to line up those studs in mid-air, least of all in the rain or mud or hanging off a 1000' cliff or whatever.
My license plate is just zip-tied to the arm for now, still using the factory light, but you'd never know it, cause you'd be blingded.
Old 07-11-2007, 04:48 PM
How are you still using the factory light?
