07-14-2007, 05:11 AM
BUZZING SOUND WHILE ACCELERATING???
2006 SUT all stock 17k miles. I have noticed a buzzing sound when under low speed acceleration. Any ideas? Thanks M
07-14-2007, 02:23 PM
Re: BUZZING SOUND WHILE ACCELERATING???
No. Be more specific.
Where is the buzzing sound coming from? Does it change pitch with RPM's?
Help us help you:
Cockpit = OnStar mic
Engine = ?
Trans = check fluid first
Diffs = ?
Sunroof = ?
07-14-2007, 06:38 PM
Help us help you:
Engine = ?
Diffs = ?
Sunroof = ?
Center Consol = Wifey's battery powered buddy
Glove Box = Your battery powered buddy
Fissed
07-14-2007, 10:21 PM
It only happens while under acceleration at low speeds and only for a short period of time. Buzzing sounds like fuel pump to me. Not any type of alarm. More of a high pitch whine. It lasts for about 3 seconds then goes away. It happens almost everytime I take off. No change with RPMs. Sound is coming from around the engine. Thanks M
07-14-2007, 11:30 PM
Maybe it's the factory supercharger whine -
Turn the wheel all the way to lock with the truck on - maybe low power steering fluid.
07-16-2007, 01:17 PM
Mine (2005 SUT) has done the same thing for over 40,000 miles. Dealership couldn't figure it out, so I've just ignored it.
07-16-2007, 08:11 PM
Could be bees. This works for me...
66' VETTE STINGRAY
07' Z06
07-17-2007, 07:28 AM
I've ignored so many sounds out of existence........... Working on a front end clunk right now.
07-18-2007, 05:40 PM
Roughrider, I've got the same sound. I took it to the dealership and they couldn't figure it out. I was able to localize it to something related to the throttle body. I took the air filter out and put it back after blowing it off and the pitch of sound changed. I have about 12k miles on my 06' and it just started about a month ago. If the windows are down its more noticeable right around 2-2500 rpm.
06 H2 SUV....stock for now!
07-21-2007, 11:59 PM
Ensure the air filter is fully seated into place, seen too many to count that were not properly installed and intake air passed by the filter. I use A small prybar to push the filter into the housing and it will then drop into place. You should see A small retainer at the bottom of the filter holding it into place if it is installed fully. Its A very tight fit so if it went into place easy it likely is not seated
07-22-2007, 03:00 AM
Thanks, I'll check!
Hybrid Mode
