Old 07-26-2007, 04:11 PM
twenty2's Avatar
twenty2 twenty2 is offline
Default What kind of battery?
Looks like my battery in my 2003 H2 is finally dead. Turned to crank it this morning, and nothing but ticks and a "beep beep" horn. I knew it was going low in amps a few months ago when I had it checked, but I figured it would last until the fall.
Anyways, what kind of battery are you guys running when you had to replace it? Did you stay with the same kind or different?
Old 07-26-2007, 04:32 PM
H2-USA's Avatar
H2-USA H2-USA is offline
H2-USA is an unknown quantity at this point
Smile Re: What kind of battery?
I replaced the orignal battery in my 2003, after is was leaking all over the front tire....... after just under 2 years.(forget the delaer)
I replaced it with a yellow top Optima battery. About 6 months ago, after only driving my vehicle every couple of days (short distances), the battery would act as if it were almost dead and not start the vehicle, I would jump it and be fine for the rest of the day, only to have it occur a few days or weeks later, or if it was really cold in the mornings (40s).
I contacted Optima, and they stated that they do not make a battery for any of the 2003 - 2007 Hummer H2s. They said that the stated cold cranking amps required (in the book) for the H2, is 880. The Yellow top Optima only has 750, and the Red top Optima only has 800.
I tested the battery, and it was only carrying 8 volts and dropped to 5 under load. After fully charging the battery it seemed fine ................
Long story short, I called Sears, they don't have a battery for the H2, though he said that could get one to fit .......... max 800 cca.
I went to Walmart and Sam's club, their books list the H2, but no battery options.
Finally I contaced AutoZone. They have a direct replacement 880cca battery for the H2s. 79-DLG (Duralast Gold) $99.99
8 Year/96 month warranty with 36 free replacement period.
DONE - GAME OVER. The H2 event starts faster with this battery, turn the key and rrumpp it's ready to go.
This is my story. Others wil swear by the Optima Batteries, which I did so before. My other vehicles have the Red Top Optimas.
Happy Trails.
Old 07-26-2007, 04:43 PM
twenty2's Avatar
Default Re: What kind of battery?
wow! Thanks for the info! That helps alot.
Old 07-26-2007, 10:41 PM
Tallowood_Air's Avatar
Tallowood_Air Tallowood_Air is offline
Tallowood_Air is on a distinguished road
Duralast Gold all day every day.
If you want an Optima, get the Red top.
The Optima yellow top is a deep cycle battery, which is good for applications with heavy, extended draw. A good example would be a large stereo system.
The Red Top is a 'starting' battery that will give you massive CA and is more like a regular battery
2007 SUV LUX All-Terrain Blue
Polished Radix Magnacharger; 2.8" pulley; Tuned by HESCO; Custom 4L80E "Raptor" by PACT
GM 2500HD Efans on SPAL controler; K&N filter element; Dynatech Headers + Cats; Magnaflow cat-back
37" Kumho Road Venture MT KL71 on 24" ZINIK Mazotti
Pioneer AVIC-Z1 HDD navigation; 2 x 12" JL W6; Custom Box w/ Lights
Old 07-27-2007, 02:30 AM
twenty2's Avatar
DuraLast Gold worked perfectly! Thanks for the info. When I got my original battery checked at Autozone, it read 10.4!! Very dead battery.
Anyways, the rig fired right up when the new one was installed!
Old 08-10-2007, 02:37 AM
pteam's Avatar
pteam pteam is offline
pteam is on a distinguished road
What should a battery read 12v when not running and 14v when the car is running/charging?
Also is there a cheap/semi-cheap way to test batteries besides a load tester? What do they use to actually test the volts of a battery?
My cars:
Lamborghini Murcielago
Supercharged Viper 800 HP Special Edition #49 of 50
Porsche Boxster S
My Hummers:
08 H2, 22 in rims, 6 HID lights, 20 in TV with DVD
4 H2 limos 3 have lighted dance floors + ceilings, 1 has Zebra interior 24-26 passengers
H2 Limo 26 pass lighted dance floor (sold)
H2 Limo 24 pass (sold)
03 H2 (sold)
H1 Open top (sold)
FirstClassLimos.net - H2 limos and party buses in OH & PA
my car collection
Old 07-27-2007, 05:35 AM
H2bill H2bill is offline
H2bill is on a distinguished road
Happy Trails.
That is some very useful information. Thanks for posting it.
Old 08-02-2007, 08:41 AM
freytes2004's Avatar
freytes2004 freytes2004 is offline
freytes2004 is on a distinguished road
I replaced mine with a red top and it works perfect I even run a 12000 pound warn winch.
Old 08-02-2007, 06:16 PM
audiofetish's Avatar
I just found out that optima has a new yellow top battery with 900CCA. It is model number D31T. Has anyone else seen this?
09 Challenger R/T
95 Heep Wrangler
90 5.Slow
99 HMC4 Sold
01 HMCO Sold
04 H2 Adv Sold
03 H2 Lux Totaled
HOPE Volunteer
Old 08-02-2007, 08:30 PM
IRA51's Avatar
IRA51 IRA51 is offline
been useing yellow top's for 3 or 4 years , work well for me . OPTIMA® YellowTop Battery
Click image to enlarge
Where loud comes from.
OPTIMA Yellow Top batteries, featuring SPIRALCELL Technology, are designed for all of your deep cycle needs. It's perfect for people who are serious about sound. OPTIMA's power is cleaner with higher voltage output than conventional batteries. You can play your system louder and longer. And they have a greater cycle life so they can be drained and recharged more often. Plus, they're spill-proof and can withstand 15 times the vibration of ordinary batteries.
Sport Compact Power
The sport compact market has continued to grow in size and advance in technology over the last few years. New developments have created demanding electrical systems requiring a high performance deep-cycle automotive battery. OPTIMA batteries can meet the needs of more enthusiasts in the performance market. Our new group 51, 35 and 75/25 sizes are made just for your compact power needs.
Unequaled Vibration Resistance
Using OPTIMA SPIRALCELL Technology, cells are tightly compressed into supportive chambers, giving OPTIMA batteries over 15 times more vibration resistance than traditional batteries. This translates into longer battery life in high vibration applications.
Nonspillable
Due to its completely sealed case, the OPTIMA Yellow Top battery is extremely safe and corrosion resistant. Acid can't leak or spill, making them clean, user-friendly and environmentally sound. In addition, the maintenance free sealed case design eliminates the need to add water or clean terminals.
Dual Purpose (Starting and Deep Cycle) Batteries for Professional Use
OPTIMA YellowTop is made to install and forget. No matter the conditions, be it dampness, heat, dirt or exposure to extremes in vibration or regular discharge, you can count on OPTIMA to deliver uninterrupted power. OPTIMA's ability to hold a higher voltage during the discharge cycle makes it possible to utilize more of the stored power in the OPTIMA compared to ordinary batteries. The YellowTop handles many discharges as well as re-charges without losing significant capacity. OPTIMA is also ideal for seasonal use because of its very low self-discharge rate. That means you can store your seasonal vehicles all winter without regular charging and still spring out of the starting block when winter is over.
Remember:
A dark gray case means starting technology, a light gray case means dual purpose (engine start and deep cycle) technology.
OPTIMA YellowTop Benefits
Dual Purpose starting and deep cycling.
Lasts up to 2 times longer than other batteries.
Constant performance quality keeping your battery running at the same level even as it's being discharged.
More power in the initial 1, 3, 5, and 10 seconds of the starting process than comparably rated conventional lead acid batteries.
Ideal for seasonal use, fully charged, it can sit unused for up to 12 months at room temperature (or below) and still start a car.
15 times more resistant to vibration than other batteries.
Nonspillable and can mount in almost any position.
Home | Product Info | News | Sponsorships | Ads/Promos | Battery Search | Contact Us | About Us
Copyright © 1996-2004 Johnson Controls, Inc. Milwaukee, Wisconsin
OPTIMA® and SPIRALCELL® Technology are registered trademarks of Johnson Controls Battery Group, Inc.
A government big enough to
you have.
-- Thomas Jefferson
