Old 09-03-2007, 01:56 AM
H3HUMMER's Avatar
H3HUMMER H3HUMMER is offline
H3HUMMER is on a distinguished road
Default Help
I bought a H3 factory switch for my offroad lights which came off a H2.
Ok only three wire i did every cobo that could be done and still can not make them work with the switch.
AND IDEARS?
Old 09-03-2007, 03:06 AM
tower's Avatar
tower tower is offline
Default Re: Help
Buy yourself a VOA meter. Learn to check continuity (Ohms). Use the meter to figure out which two contacts have zero resistance (ohms) between them when switched on. Those are for the positive lead and the load (lights). To figure out which is which, connect the third lead to a ground source (e.g. bare metal car body) and see which of the first two contacts lights up the switch in the ON psition only. That one gets the positive, the other gets the load.Post photos when complete.
Old 09-03-2007, 04:05 AM
3Hummer's Avatar
3Hummer 3Hummer is offline
Default Re: Help
or just have the dealer put it in
2017 VW Jetta S
2012 Cessna 182T Skylane
/''T''|[___|___]
[---T--L -OlllllllO-]
()_)"""()_)/"**"\)_)
Old 09-03-2007, 05:03 AM
trailerpup's Avatar
Default Re: Help
Pin A - Power input from relay or lamps that powers the internal LED. (Inside the switch, this circuit goes directly to LED and then directly to the ground circuit inside the switch.
Pin B - Ground
Pin C - Used by relay for ground. This is the circuit that goes into the switch and connects to ground when the switch is pressed.
Courtesy of f5.
Old 09-03-2007, 10:00 PM
Default Re: Help
i guess turning the radio up wont help this problem...
