09-07-2007, 01:52 PM
In-op wipers/washers - 2003 H2
Recently my windshield wipers decided to operate on their own, literally, without them being on. The only way to stop them was to pull the fuzes. Now, after replacing the fuzes, the rear wiper works however the front one doesn't. Has anyone experienced anything similar to this, and if so, what's the solution?
Thanks in advance!
09-07-2007, 08:57 PM
Re: In-op wipers/washers - 2003 H2
Thanks in advance!
G.
I've had that happen on chevy trucks before. It is either the switch on the stalk or the wiper motor/module or a combo there of. I cannot recall what they did in the silverados to fix that problem, but I do know it was an $800 bill!
Stop by the office next time you are up my way and check out the 08 H2 I just bought.
2009 H2 Silver Ice LE
09-08-2007, 01:12 AM
Typically the wiper module is at fauly, water intrusion on the circuit board. On the older ck platform cold solder joints on the circuit board caused many wiper issues and could be fixed by soldering the joints again, or replace the module. In your case replacement is in your future. I dont think the part is too expensive but the cowl needs to be removed and are A pain in the a** to get off. hope that helps.
09-08-2007, 07:15 PM
Same thing happened to me. check out my post about my wipers gone wild.
09-14-2007, 07:28 PM
I took my truck into the dealer and advised them of the situation regarding the bulletin about the wiper motor. The dealer ran my VIN and said that there was no recall on the motor. I contacted HUMMER and advised them and they too said that there was no recall. I remained very adament about the bulletin, and because of this I guess it helped, since HUMMER contacted the dealer about it and agreed to pick up the bill minus a $50.00 deductible.
Also, I need to add that HUMMER did acknowledge that there were some wiper motors that had an issue, however upon disassembly by the dealer, they said that my motor wasn't one of the faulty ones......They still covered it though.
Hope this helps anyone else who has to go thru this.
11-28-2007, 03:26 AM
Digging up a old post here.
My wipers had all the problems listed here on this site yesterday and till today except the washer spraying till empty, when I took matters in my own hands tonight.
Pulled the module apart to find exactly what HUMTECH said would most likely be the cause, WATER.
I took the ole trusty air hose, blew the water out. Took some contact cleaner to the circuit board, then added black RTV sealer to the existing foam seal, put it all back together and presto the wipers work as before. Cost, just some of my free time to find out how things work.
Just in case others want to take the time to fix something themselves.
Later, Easy Ed
Attachment 44888
Attachment 44886
Attachment 44887
Hybrid Mode
