Old 09-20-2007, 06:37 PM
subunix's Avatar
subunix subunix is offline
subunix is on a distinguished road
Default Adventure Package
If youre going to do a lift would you still need the adventure package or is it a waste of money
"We don't do pretty"
Old 09-20-2007, 06:46 PM
D-MAX's Avatar
D-MAX D-MAX is offline
D-MAX is on a distinguished road
Default Re: Adventure Package
adventure package is the better shocks and d-locker, not to sure but pretty sure, oh and 33'' tires instead of 31''
2007 h3x
2006 GMC 2500HD DURAMAX
Old 09-20-2007, 07:13 PM
Desert Dan's Avatar
Research what is in the Adventure Package then decide
Look at the brouchure
Desert Dan
Jeep TJ Rubicon 2003
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
Old 09-20-2007, 07:32 PM
subunix's Avatar
Looking at doing lift probably rancho's and will do 35" or 37"s, does anyone know of an aftermarket locker setup? The only thing that i really like about the adventure package is the locker because ill probably change everything else out
Old 09-20-2007, 07:47 PM
fourfourto's Avatar
You also get granny low 4 to 1 ratio.
I think when I bought mine they give you carpeted mats (I covered them with the mudder mats) and a left side cubby if you dont have the sub.
Old 09-20-2007, 11:04 PM
BST1YET's Avatar
BST1YET BST1YET is offline
BST1YET is on a distinguished road
You can get an aftermarket locker from Eaton for about $800 (pretty sure it is the same one that is used as O.E.) If I was you save the money, buy a base, and put your savings toward the lift, aftermarket locker, tires etc.
just my 2 cents
07 H3 Base, auto, Black w/ black interior, chrome door handles and mirrors, leveled on rollin on Goodyear MTR's
Old 09-20-2007, 11:11 PM
fourfourto's Avatar
just my 2 cents
I only paid $1,100 extra for the adventure package .
Seems like a no brainer
Old 09-21-2007, 07:30 AM
Such as?
Unless, you're planning on swapping out the axles, getting the Adv. package is a no-brainer, and a helluva better deal than trying to piece it together aftermarket. Plus its all under warranty.
Old 09-21-2007, 08:19 AM
RuggedH2's Avatar
RuggedH2 RuggedH2 is offline
Just like Sewie, Tomp and others said, If you plan to off road the adventure is the way to go. You probably won't be planning to change the transfer case with the lift, and that gearing makes a difference off road, besides the locker.
Old 09-21-2007, 04:35 PM
tomp's Avatar
tomp tomp is offline
...Just wanted to add that the lift he wants to do will make the lower TC gear even more of a reason to get the adventure package - assuming his tire diameter will increase.
