09-21-2007, 07:18 PM
H3 Engine Performance Up-grades
I just purchased a 06 H3 and love the rig, but like most wanted more power. I just installed a K&N cold air intake (dyno claims 18.7 HP) I also put a flowmaster muffler and removed the stock exhaust resinator with a straight pipe. I noticed a nice increase in power, but wanted more.
I am interested in the: JET Performance Chip. The stage 1 dyno claims 15HP, the stage 2 I have not seen any dyno claims. Has anyone done the JET chip?
09-21-2007, 09:31 PM
Re: H3 Engine Performance Up-grades
Check the intake snorkel, the pipe that goes to the fender. It has only an 1.8 inch inner diameter. This forms a restriction because the diameter of the rest of the intake piping is 3 to 3.5 inches.
Replace it with a 3" short pipe or similar. Just remember to seal it right.
Victory Red 2006 H3 Luxury, Automatic, OEM steps, Sunroof. MODS: Torsion bars 4X, Front Bilstein shocks, Front adjustable swaybar links, Rear Rancho shocks, rear 6.5 inch shackles, Rear Quick disconnects swaybar links, Black rims, Hidden hitch, Husky mud flaps, Trasko spin on filter, No intake resonator, Enlarged 3" snorkel opening, No muffler
09-21-2007, 10:33 PM
Ain't NO WAY !!!!
09-21-2007, 10:43 PM
Can you say Alpha?
If you really want more HP save your money and put it toward a V8 Alpha
There is no substitute for cubic inches.
Desert Dan
Jeep TJ Rubicon 2003
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
09-21-2007, 11:24 PM
According to JET's website they don't make a chip for the H3. Just the throttle body spacer.
09-22-2007, 01:50 AM
The JET chip is for the Chevy Canyon P/U with the same engine. I was told it would work with the 3.5L in the H3
09-22-2007, 01:52 AM
Regarding the K&N cold air-intake:
The 18.7HP gain is the dyno sheet that came with the K&N kit. This not my dyno, but what K&N is marketing...
09-22-2007, 11:33 PM
Look at what rpm they got that gain. At 6000 rpm. How often are you running your engine at 6000 rpm?
You will definitely hear a difference, which will lead you to drive different, which will make you feel like there is a difference with the new intake.
Don't get me wrong, I like the idea of a high flow intake, but I don't like having an exposed air filter in an engine bay that gets pretty dirty from offroading. Some people have reported issues with their mass flow air sensors from the oil that comes off the filter.
When I had my K&N installed I heard a noticeable difference, but the air resonator was removed to put on the intake. Now that I have gone back to the stock air intake, I don't feel a difference between the two.
09-23-2007, 03:58 PM
I have the K&N kit and feel the difference. I have a 5 speed and yes the difference is only at the high end of the tach. I keep it revved and it is noticable between 4-6000.
Very annoying vibration at idle and I have to feather the throttle at a stop sign.
Does anyone know if idle can easily be raised a couple hundred RPM to make this go away?
"I didn't mean to wreck him, I just wanted to rattle his cage." D.E. 1951-2001
03-09-2011, 07:48 AM
Did the air intake and the new muffler reduced your miles per gallon?
04-07-2011, 11:13 AM
i would go by the book. the added power comes at the maximum rpm limit. but one doesn't normally race at that kind of torque, so just check if adding JET is worth it or not.
Hybrid Mode
