10-05-2007, 03:03 PM
h2 driver side mirror
i have 2003 h2 my driver side mirror will not work and is loose,also as i drive it closes. is it true the dealer will fix or replace it with a new one and if so can someone please give me a link so when i go to the dealer with this fight i will have some ammo.
10-05-2007, 03:07 PM
Re: h2 driver side mirror
They wont replace unless you are under warranty is my understanding
Use the Search Button
This was covered 2-3 weeks ago its Fresh.
I was at Cerritos Hummer yesterday and asked the parts guy about this in person, there is no amnesty or grace period at all, If your not under warranty your out of luck.
Each mirror at the dealer is 410.00 each
Good Luck
Also read your manual in the glove box, it tells you how to re-set these, may work?
10-05-2007, 04:10 PM
There is a SB on this, so they may do it anyway. But not if you don't try!
10-05-2007, 10:42 PM
I was told by the Service Manager at Hummer that:
My Rig is a 2004 and out of warranty and he plugged in the Vin # and it pulls up no Re-calls for the Mirrors and im **** out of luck.
He did say that my Rig is due to be upgraded for Digital Onstar for the cost of 219.00 for this and that includes 1 yr of Onstar, and If its not done by Mid November it will never be able to be done?
WTF, I think they smell my wallet?
10-05-2007, 10:50 PM
10-07-2007, 05:08 AM
If you go to the dealer and bitch enough you might get A goodwill warranty repair or A 50/50 split but both mirrors would need to be replaced as the 03 mirrors are not available anymore, they would install the new style mirrors.
10-21-2007, 04:39 PM
Good Luck
Your manual states this same thing as previously stated.
Glad it worked out.
10-21-2007, 05:50 PM
I just replaced them! and the signal mirror glass too since the mech broke one of them. Well its time for another beer.
2013 Sierra Denali
2012 Yukon Denali
1974 Corvette conv. (454ci)
31ft Gulf Craft Boat
10-22-2007, 08:02 AM
Yes, read the manual. I also thought that ours were broken, as they were loose. Drove like that for a long time. Then my wife figured it out! The holding down the mirror button thing worked like a charm. It resets the gears inside the mirrors.
10-21-2007, 09:56 AM
I have a 2003 H2. I thought both my side mirrors had been bashed in and ruined when my passenger door was keyed in Yosemite Valley over a year ago. Both mirrors were loose, and despite repeated times of pushing them outward they would not hold in place. Driving was a pain, but I didn't have the funds to replace both mirrors. In May, while at the Ontario Hummer dealership, (CA), I mentioned the problem to a salesman. He just happened to be familiar with the 2003 mirrors. He pushed the button to roll the mirrors all the way in, held it a bit, then released it and they returned to a normal position. They are no longer loose, they stay in place and work just fine. The salesman admitted that not too many people know about this trick. So before you spend a ton of money, take a few and check it out. Good luck.
Hybrid Mode
