Old 10-07-2007, 07:41 PM
tower's Avatar
tower tower is offline
Default Question About Rear Bumper Lights
With a good deal of help from Hucky (thanks, Guy) my rear bumper lights are ready to physically install. They have bulbs with 2 filaments, a bright one and a dimmer one. I assume that the dimmer one is for use as a park lamp. Could anyone with an '05 or better please let me know if the brighter one is for brake, turn or both and does this apply with park lamps (or headlights?) on AND off? I am trying to figure out the wiring and fear I may need diodes and relays to accomplish the factory functions. Thank you!
Old 10-08-2007, 12:51 AM
H2 007's Avatar
H2 007 H2 007 is offline
H2 007 is off the scale
Default Re: Question About Rear Bumper Lights
The rear bumper lights serve a dual purpose. They are running / tail lights and also serve as brake / turn signal lights.
I'd say you'd be able to tap into the factory harness above and be all set.
I think these were a good add on GM / Hummer's part as I often see people riding up close behind and it gives them a brake light at eye level for smaller cars.
2008 H2 Graystone Metallic
Old 10-08-2007, 01:05 AM
R U putting back up lights in? Or are you converting to the newer style rear bumper lights?
Maybe a link as to what light you purchased could "shed a little light" as to what you are trying to acomplish.
Old 10-08-2007, 01:40 AM
Hucky Hucky is offline
Hes converting newer style lights into the end caps of the bumper just like the new models have. Using OEM Parts from Hummer
The Light sockets have 3 leads (wires) coming out of them.
Old 10-08-2007, 02:36 AM
I'll see if I can get some pics of where the wires go to on my 07 if that would help. Would it?
I can tell you that those lights to act as running, stop, and turn.
Old 10-08-2007, 07:20 AM
tower's Avatar
Yes, Tim, that would help immensely. I can tap into my existing park lights for the park lamp (lo) function, no problem there. I am trying to figure out how to wire the turn and brake (hi) without backfeeding into the existing tail lamps. I have the amber turn signals on the tri-lights, so turn and brake are separate wires. I am concerned about hooking them both up to the new lamp as this would cause all the turn signals to light up when I put on the brakes and vice-versa. The bumper lights have 3 leads. +Hi, +lo & -ground. Thanks, in advance, for any and all help.
Old 10-08-2007, 07:28 AM
tower's Avatar
Old 10-08-2007, 09:45 PM
tower's Avatar
I may have figured it out. I think if I don't connect a ground, it might work. If I connect one lead of the HI to the flashers and the other to the brake, it can pull ground through the non-working filaments. I will test and post. I wish I could say that I came up with this notion on my own, but I was inspired by something I read from Daniel stern. I was thinking about tapping into the marker lights, when I came upon this:
LINK
Old 10-08-2007, 11:01 PM
Hurry up and figure it out, Lets get this bitch sent home
Whenever your ready
Huck
