Old 10-14-2007, 07:26 PM
dkhummerh2's Avatar
dkhummerh2 dkhummerh2 is offline
dkhummerh2 is on a distinguished road
Default Towing Questions?
Hello,
I just recently bought a 24 foot enclosed cargo hauler (trailer)! The trailer and contents are going to have a gross weight of 6k lbs. I will actually use the trailer weekly. Do you think that I should use my H2 to pull it, or should I use a truck? I have on 04 Ford F-150, but it is a short box, short wheel base v6. I used it to pull the trailer home and it didn't fair very well. So I am thinking about trading the Ford for a V8 long wheel base, long box 06 Ford F 150 with the heavy duty trailering package. I always appreciate the forums opinion. Just worried about using such a nice truck (my h-2) to do that work week after week. Round trip would be about 210 miles weekly.
thanks
dk
Darin Kaiser
Old 10-14-2007, 09:22 PM
Default Re: Towing Questions?
You shouldn't have any trouble. The H2 weighs more, and might have better brakes than the F150. You have a brake box right? If you have air suspension, you should be careful to load everything for the best weight distribution to make sure the tongue weight isn't too heavy. If you have any concerns about that, then an equalizer hitch should be used or you run the risk of overloading the airbags, and the computer will shut down the suspension.
I pull an enclosed 4 place snowmachine trailer, no problem.
Have fun!
Old 10-14-2007, 09:31 PM
dkhummerh2's Avatar
Yeah I can balance the load with no problem. What length of drop hitch do you use? I do have air suspension so I would want to make sure that I don't screw with that. How does yours pull? Thanks for the input, I am trying to make a decision this week!
dk
Darin Kaiser
Old 10-15-2007, 12:08 AM
mikejr's Avatar
mikejr mikejr is offline
dk
I tow a 12 foot utility trailer (1000 pounds) and use an 8" drop. I just towed the trailer with 3000 pounds of top soil on it pulled like nothing was back there. Tow haul mode works great. In the 08 when you have tow haul active it auto downshifts the tranny when you start breaking, pretty damn slick! I could tell the load was back there when braking, but not really when I was accelerating.
2009 H2 Silver Ice LE
Old 10-15-2007, 01:51 AM
dkhummerh2's Avatar
Thanks, I figured it would be about an 8 inch drop on mine as well. I guess I will hook it up and give it a try this week and see how I like it. I just don't know if I want to put that much use into it. I really like it and don't see a reason to trade it, as it only has 44k miles on it.
thanks for your advice.
dk
Darin Kaiser
Old 10-15-2007, 12:51 PM
mikejr's Avatar
If you use the H2 to haul the trailer it means more time behind the wheel of the H2....that is a beautiful thing! Its a tough truck, it will take it.
Old 10-16-2007, 05:36 AM
dk
It pulls fine, but you definitely know it's back there. The air suspension will level the ride once it's hooked up so take that into account when you hook it up. Make sure it's level after the suspension has had time to level it out. It's not the same as a long wheel base pickup, but it'll do for as far as you're going. You should be fine. Use your tow/haul button. If you have any hills to go up you'll spend the whole time in Second gear, but you'll get used to that. Sadly, it's not a diesel.
Another thing I've noticed, and anyone could disagree, is that the computer learns how your driving over distance. So if you don't use the tow/haul button, the computer actually learns how to shift for you. One thing about tow/haul tho, I think it makes it shift faster, so there's not as much lag between gears. This is good for the torque converter.
Have fun!
Old 10-16-2007, 05:38 AM
p.s. My rapid hitch hasn't ever drug the ground. FYI.
Old 10-14-2007, 09:33 PM
tower's Avatar
tower tower is offline
OMG! Rox, you have sowmobiles, newest best friend?
Old 10-15-2007, 02:23 PM
Old 10-15-2007, 06:27 PM
MVR 155's Avatar
MVR 155 MVR 155 is offline
You should have no troubles..... no reason to buy another truck, you want the ball height to be right at 18" so Im guessing that a 6" to 8" drop should be perfect. Make sure you get an electric brake control as well, that is way too big of a trailer to even think about trying to stop it with the truck brakes.
Have fun
1/4 mile: 11.661@118.86
2013 Audi S4
2002 Yamaha YZF R1 Blue/White
1/4 mile: 10.51@136
2005 Sea-Doo RXT
Old 10-15-2007, 10:29 PM
porschett's Avatar
I use mine to tow a trailer, loaded with a twin-turbo Porsche, as well as a 1956 356C Porsche. Never have a problem other than the 5.5 MPG! The whole rig weights in at 9400 lbs., but it does have disc brakes on all 3 axles.
2009 H2 Hummer It's here!!
2006 Baja Performance 88 MPH
2008 GT2 Porsche
2009 DBS
Old 10-16-2007, 05:20 AM
I use a Rapid Hitch from Andersen Manufacturing. I'm not sure where you could find one locally.
10 inch drop puts the tongue on almost any trailer in the perfect spot.
http://ultrahitch.rpmsolutions.biz/index.cfm?section=73
The Rapid Hitch - This is the revolutionary aluminum adjustable ball mount that has taken the hitch world by storm. No ball mount is more versatile or easier to use than the Rapid Hitch. Its adjustability allows you to tow easily and safely by keeping your trailer parallel to the ground, maintaining a more stable towing experience.
The Rapid Hitch is made of an aluminum super alloy that will NEVER RUST! The aluminum looks great by itself, so there is no need for paint or chrome that can chip and peel. To keep the shine, you simply need to polish the hitch from time to time and you will have a high gloss surface that looks brand new.
Another benefit to this aluminum super alloy is that it is light and surprisingly strong. It only weighs 15 lbs. with the greaseless ball option making it easy to handle and adjust. It is V5 certified with a strength rating of 10,000 lbs. and 1,500 tongue weight with the 2 5/16" steel ball. The Rapid Hitch is built for the long haul...the real world where ease of use and strength really count.
The Rapid Hitch is available in three drop sizes - the 3 1/4" drop/rise, the 5 1/4" drop/rise, and a full 10" drop. The 10" drop is recommended for lifted vehicles and has adjustment options from approximately 4" of drop to the full 10" drop. The standard 5 1/4" drop/rise is designed to fit all factory standard pick-up trucks. However, we have discovered that in some instances the standard Rapid Hitch will drag on the ground in a dip, so we have added the SUV Rapid Hitch to help eliminate this situation. The shorter SUV Rapid Hitch works best with most light trucks, ½ ton trucks, and SUV’s. A quick and easy way to judge what size drop you need is to measure from the ground up to the inside top of your 2" receiver tube. If the measurement is 20" or less - the 3 1/4" drop is for you. If the measurement is between 20" and 24" you need the 5 1/4" drop. If you measure more than 24" you will need the 10" drop. The tongue heights of your trailers and the suspension on your truck play a part, but in most cases these measurements will give you what you need. If you are unsure, please take your truck to your local dealer for advice.
The Rapid Hitch is the perfect hitch for anyone who tows multiple trailers. You can flip the double ball over, change the drop to a rise, or adjust the height of the drop all by simply removing the hitch pin and putting it back in place. With the easy height adjustment you can make sure you are keeping your trailer level. With the 2" and 2 5/16" ball combo, you cover most trailers on the road today. We also have a combination ball that includes the 1 7/8" and 2" ball. The 3 common ball sizes (i.e. 1 7/8", 2" & 2 5/16") are available individually if desired. The various balls are easily changed by removing a hidden pin which attaches the ball to the ball housing. (See instructions for further details.)
When only the best will do...you need the Rapid Hitch – The easiest to use and most versatile ball mount system available today.
All Rapid Hitch sizes have a 10,000 lb. GTWR and 1,500 lb. tongue weight - limited by ball capacity.
  • Standard double ball features 2" and 2 5/16" balls.
  • 3 Models available: the SUV 3 1/4" drop/rise, the 5 1/4" drop/rise, and the 10" drop.
  • The standard Rapid Hitch has 10 ½" over-all vertical adjustment, 5 1/4" rise or drop.
  • Fully tested and cerified by an independent lab.
  • Fits a 2" standard receiver hitch.
  • Many optional balls available including:
    • 1 7/8" x 2" combo
    • 1 7/8" single ball
    • 2" single ball
    • 2 5/16" single ball
  • All ball sizes are available in zinc plated steel or greaseless aluminum.
  • Light Weight...yet extremely strong.
  • Anti-theft keyed locking pins available.When only the best will do...you need the Rapid Hitch – The easiest to use and most versatile ball mount system available today.
