Old 12-03-2007, 08:32 AM
dna dna is offline
dna is off the scale
Default air suspension - how can I keep the rear at the full 'height control'
Is there any way to keep the rear at the full height when I hit the 'height control'? Mine goes up, but at about 60kms it automatically goes back down. I like the look of it at the raised height. How can I keep the truck at this height without it going down. I do not want a permanent method, as I may want to ocassionally have it go down, but I just don't want it to go down by itself at 60+ kms.
Old 12-03-2007, 10:01 AM
Default Re: air suspension - how can I keep the rear at the full 'height control'
The body control module I think is where you would have to look to hack to do what you want. You may be able to bypass by hard wiring the pump in the rear seperate so you can control pump.
The purpose of the module control is to sense when you go below 25mph it raises the back thinking offroad. It lowers above that speed to give best ride quality. When towing you can push the load leveling so that even at faster speeds the rear will raise up.
I doubt I have been any help. Hopefully some Hummer Techs will really be able to give a clear answer.
TAZ
Old 12-03-2007, 03:32 PM
TXSUT's Avatar
TXSUT TXSUT is offline
It's actually 40mph on my 2005, and once it lowers automatically, you have to hit the button to raise it again (i.e., it's not a continuous-on feature).
Old 12-04-2007, 08:59 AM
Sorry on the mph it is 45mph hit a typo and it will raise below and lower above automatically. At least mine does and i have made no mods.
Making it stay up as mentioned here already looks like fooling the sensors.
Good Luck
TAZ
Old 12-04-2007, 11:41 PM
40 mph, it goes back down. If you like the raised look, go for the Rancho lift.
Old 12-06-2007, 07:44 AM
finall finall is offline
FYI: 60 kph is about 40mph.
They lower at the same speed, whether it is mph (domestic) or kph (export unit). Done for safety reasons. Read your owners manual, it describes this.
Old 12-04-2007, 12:52 AM
thats all way to much work... the easy fix is....drive slower.....its actually 45mph in case anyone was wondering....
