Old 12-05-2007, 06:05 PM
twenty2's Avatar
twenty2 twenty2 is offline
Default New Hub/Bearing
Just wondering if any of you have had to change your hub at all? And, knowing that I have to change 1, should I just do both????
Old 12-06-2007, 12:41 AM
orlasttoy's Avatar
orlasttoy orlasttoy is offline
orlasttoy is off the scale
Default Re: New Hub/Bearing
just had mine changed on an '03 w/ 61k miles...
thats all i know...100% trust in my dealership HAAAAAA
Old 12-06-2007, 12:51 AM
H2 Bill H2 Bill is offline
What kind of symptoms did you have?
1994 Chev Suburban Blown
Old 12-08-2007, 01:29 AM
1GaNole's Avatar
1GaNole 1GaNole is offline
1GaNole is on a distinguished road
I had to replace my front right hub in June, '04 with 80k miles. $350 plus labor.
Old 12-08-2007, 03:11 AM
Yetti Yetti is offline
if you suspect a bad hub or bearing do a couple of quick tests while driving. you will need a road with a long curve like an exit ramp. if you hear a howl or hum from the suspect bearing put it into the a curve to transfer weight away from the bearing. if the noise quits its most likely the bearing on the inside of the turn. I have also found if you back up at low speed with the wheels cut hard one way or the other you can find bad CV joints, listen for the then to "Clunk" repetedly while turning.
Yetti
www.greatlakes4x4.com
www.wegotmud.com
www.glfwda.org
Old 12-18-2007, 07:21 PM
dochummer's Avatar
I have that problem with turning right on off-ramps. My right WB is bad. I found them on ebay for $140. Just haven't bought one yet. Shouldn't be too bad to replace it yourself...
'03 H2
