Old 01-19-2008, 09:16 PM
05h2sut 05h2sut is offline
05h2sut is on a distinguished road
Default Actron CP9180 scanner
Hi All,
Anyone have any suggestions....
Check engine light came on, so I stopped and picked up the Actron CP9180 scanner. Plugged it in under the dash - nothing. It was supposed to power up... Plugged it into my pickup & live was good.
Something I don't know about with Hummers? Its an '05 SUT if it matters.
Thanks,
Dave
Old 01-19-2008, 10:52 PM
JetEyeNite JetEyeNite is offline
JetEyeNite is off the scale
Default Re: Actron CP9180 scanner
I had same problem as you... Check your cigarette adapter and see if you have power. I found that the left most cig adapter has no power... I heard somewhere that the OBD and cig adapters are on same circuit? I checked all my fuse and they are all fine? something isn?t quite right?
Anyway, I ran power from fuse box to the OBDii to supply the power?
04 Pewter Lux
Old 01-19-2008, 11:20 PM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Check cigar fuse under hood
Old 01-19-2008, 11:25 PM
Thank you both - most likely what it is - as a smoker, I noticed that the lighter stopped working since the last time I had that facia off to get at the radio. I probably grounded the hot lead by accident and popped the fuse. I never would have figured that out.
I'll check in the daylight - thanks again!
-Dave
Old 01-19-2008, 11:53 PM
Exactly - the 15 A under the hood.
The code was a P0332 - knock sensor Background Noise Low Fault Bank B
Probably a cold weather crap gas thing...
Thanks again, good to know I didn't waste $175 on the scan tool.
-Dave
Old 01-20-2008, 11:55 PM
Humtech,
Thanks for the tip...
I checked and the fuse for cig under the hood was blown...
04 Pewter Lux
